BURNER STATUS LIGHTS START FLASHING, SHUTS DOWN!
WHEN YOU TURN ON THE HEATER, IT WILL CYCLE ON. WHEN THE BURNER STSTUS REACHES HALF WAY IT SHUTS DOWN WITH THE BURNER STATUS LIGHT FLASHING. PLEASE HELP!
Not sure exactly what is meant by half way it shuts off. My furnance wouldn't heat to 68 degrees from a setting of 63 degrees on the setback thermostat without shutting down several times with a single flashing led. It would reset after an hour or so until it finally reached the 68 degrees. The problem turned out to be the tube that drains the water from the blower assembly. It had a belly in the middle which would cause the water to sit and block the airflow sensor for the gas value. Lifted tube to allow proper drainage to correct.
Posted on Dec 24, 2008
Any suggestions on most likely problem?
it should tell you that flashing code of it problems
Nov 17, 2014 | Heating & Cooling
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Ihave a 441 monitor kerosene heater,burner status light are flashing and the heater shuts down.the heater has had a turnup, tank filter has been replaced, flow has been checked,igniter or flame dtecti
look and see if the part that stubs out the wick upon turning it off is stuck up or not dis engaging properly. if stuck up the over heating would shut it down!.
Jan 04, 2013 | Heating & Cooling
Have a GF500 Monitor Propane Heater - keeps shutting down. Once it reaches the set termperature the burner begins to back off, and then the "burner status" buttons start flashing and the unit...
This sounds like your thermo-couple has a short, or is defective, it is supposed to kick off at the set temperature, then turn the burner back on after it cools down, a temperature probe is usually coonected o this as well, either one of which could be defective. Try to replace those parts and see if that does the trick.
Jan 17, 2011 | Heating & Cooling
It is a new Saeco Odea Go machine. Every time I turn it on the indicator lights flash up and down successively and a half inch of water comes out of the coffee spout. The light is then in the ready...
What will the machine do when you turn it on? The green light will start flashing for warming up phase. When it reaches the working temperature, all the lights start flashing in anticlockwise direction and the brew group moves up and start pumping water to rinse the system.Of course half an inch of water will come out from the spout. That is normal.
Sep 10, 2010 | Saeco Odea Go
Dryer goes on, and will start burner but will not reach operating temp. Shuts burner off almost immediately. Will start burner again in cycle but then shuts off before it reaches operating temp.
What brand? You could have a clogged vent, or a stretched out belt, allowing too much heat inside the drum, triggering a safety switch.
Jun 22, 2010 | Dryers
Intertherm furnace won't work
sounds like inducer problem cannot open presure switch so shuts off on safety
Apr 29, 2009 | Heating & Cooling
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
Laser 73, burner lites, then green yellow red lights all flash for about a minute then unit shuts down ee-2
I was told all lights flashing means the pot is flooded. Unplug your heater. Take take the cover off. Unscrew the igniter and pull it out. Roll up a piece of paper towel, put it in there and see if it absorbs any fuel.
You could also be in need of a cleaning. If your burner pot is full of carbon, a chain of it will attach itself to the flame sensor rod, thus putting out the fire. Also if your burner ring in the burner pot is too warped this will put the flame out.
Dec 09, 2008 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
414 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
