Question about NetGear DG834G Router
I cannot get connected to the internet.
Hiya I've got two computers at home connected by Netgear DG834G. For a short period of time, both the computer didn't have proper access to the internet. Now, my main computer has a internet connection whilist the one connected with the wireless network hasn't. There seems to be no internet whatsoever, and the netgear itself isn't connected to the computer :s. When i try to connect to the internet on AOL, it says that the DNS server is unreachable or unavaliable. There was also a message saying i have a "I.P. conflict with a computer connected to the network". I was hoping that someone could help me fix the problem before the new year =). thanks for the help.
  • 1 more comment
  • Thidarat Udomritkul Dec 31, 2006
    thanks for the solution so quick =).
    yeah i reseted my settings and tryed to reinstall the wireless network on the connecting computer.
    it's a weird problem though i don't think its anything too technical. Just that when i try to load up the Netgear CD in the computer, the program never loads up and it doesn't work manually either.
    Basically I'm at the part when i need to reinstall the wireless network on the alternate computer, but i can't do it without the Netgear cd loading properly :(.
  • Anonymous Nov 11, 2007
    cant get connected
  • Anonymous Mar 30, 2014
    While taking backup of installed OS in hard-disk using Redobackup, After some time the backup process hangs and it is disabling Internet connectivity to all other computers and gateway IP being unreachable from all other computers in the network. During the start-up of Redobackup live cd, it was getting IP using DHCP.
  • 624 Answers
If I understand you correctly you currently have a computer connected directly to your ADSL Internet connection and it can connect to the Internet. When you disconnect the computer, connect the DG834G router to the Internet connection and then connect the computer to the router you loose the Internet connection. It sounds like a ?simple? case of the router not being configured correctly. What I would suggest is to reset the router to its default configuration and follow the installation instructions again from the start. I?m not a big fan of the software configuration wizards that these home routers come with BUT they are the best way to easily configure the typical installation. To reset the router: in-between the 4 Ethernet LAN ports and the ADSL port there is a small reset button. Press and hold the reset button until the test LED turn on (about 10 seconds). Release the button and wait for the router to reboot. Let us know if this works or not. If you still have problems the more details and error messages you can supply the better.
Posted on Dec 29, 2006
  • tomj23 Dec 31, 2006
    I couldn?t find a download link for the SmartWizard on NetGear?s site so short of calling them the next best option is to try the manual installation method. Your manual should have the process but the process is also outlined here:http://kbserver.netgear.com/inquira/defa... I personally find this method far easier but then again I didn?t think Windows back in the 90s was easier either .
    Also in case you haven?t already found it here is the link to NetGear?s troubleshooting procedure for this device:http://kbserver.netgear.com/kb_web_files...
    Again Good luck and let us know how it goes.
Netgear DG834G router dropping internet connection
You could try a firmware update, if this is no better it may be time to ask your ISP for new router.
Aug 01, 2010 | NetGear DG834G Router
Don't have home phone and looking to buy router/modem.
Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
May 08, 2009 | NetGear DG834G Router
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
No dsl/ internet lights
Contact your ISP. There are some companies that deactivate your internet connection after inactivity for a period of time. They have to reset the D-Slam.
They will also have you power cycle your modem.
Jul 04, 2008 | NetGear DG834G Router
Netgear DG834G Router
It's not unknown for this to occur, and usually it's caused by Windows updates. In any case, try re-installing the programs themselves to rule out a corrupt file.
May 24, 2008 | NetGear DG834G Router
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
Can't get internet access through NetGear DG834G Router
You have to configure your router...
If your ISP provided you with IP Address, enter the assigned IP address, subnet mask, gateway IP address anbd DNS IP address for your broadband router.
If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must enter the required information.
Hope this could help..
Mon =)
Nov 15, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
181 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
