Question about Sony TA-E9000ES Amplifier
Sony TA-E9000ES Amplifier seems dead
This pre-amp was working just fine, then started making popping noises sporadically. Power off/on corrected that for a while. But now it seems dead except for orange light behind the - + mode button. Pressing the other buttons in the same row (auto-format, 2ch, audio split) will light up, but there are no other indications of power; no light on power switch, display or any other sign of life.
Does anyone know if this might be a repairable problem ?
Appreciate any suggestions...Thanks.
  • Sony Master
  • 586 Answers
     This related to the transistor which need to be replaced and it is TRANSISTOR 2SD2012.If you can change it by yourself then ok and if not then plz contact any expert nearby to you.
   Thanks
Posted on Nov 24, 2008
  • 4,234 Answers
Two things:
1) Yes it should be repairable.
2) Please confirmn the model number.
With the model number, I can verify the circuitry and provide you with better guidance on the repair process.
Thanks,
Dan
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your description of the original/start of the problem could possibly be capacitors discharging/charging or just dying out. The description of the current status leads to a probable power supply problem. Thoough the indication is the absence of some of the rquired voltages, it is also possible that the system is in protective mode hence the voltages are not allowed to go through. This is due to possible component faults that draws excessive current.
This would require that the unit be opened up for a looThis of course would require a fair familiarity of electroniccomponents/circuitry and safety procedures, use of a DVM and asoldering iron. It would be to your added advantage access to a servicemanual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhapsyour best bet would then be to seek the services of a qualifiedprofessional.k & see.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • 147 Answers
It sounds like it is repairable! have you checked the board for burns cracks or loose conections
Hi guys. Having a problem with my NAD T163 Surround Sound Decoder. Popping in front left and right speakers when changing audio selection. Works well other than that. Please give me some suggestions w
Could be DC voltage on the speaker output line, but this will generally keep your receiver audio output turned off completely. Could be a bad muting transistor or microprocessor IC(computer within your NAD). If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com.You may contact me there. Thank you..
Jan 01, 2014 | Sony TA-E9000ES Amplifier
Popping sounds when changing volume
The cracking and humming sound is because of the improper earthing
Sep 10, 2008 | Sony TA-E9000ES Amplifier
Where can i get a display panel for a sony ta-ve110
Go to www.sony.com contact customer support and the technical department to see if they can help, also try www.ebay.com type make and model and go through the list if available.
Sep 24, 2012 | Sony TA-E9000ES Amplifier
We look for remote control use fro TA-E9000ES
Try the Sony consumer website or a place call mrremote (dot) com
Nov 30, 2010 | Sony TA-E9000ES Amplifier
Sony TA-E9000es. No Display, No Sound. Software Ver 1.18. Has Bulletin HIFI1-99-028R1 performed. (Add capacitor, replace resistor)
also replace Q108 @ Q109 on power board. If that does not fix it then also replace PH101 & PH102. Also on Power board.
Jan 14, 2010 | Sony TA-E9000ES Amplifier
I have 2 questions will my SONY TA-E9000ES preamp work with my SONY STR-DG720 7.1 RECIVER and what SONY ES Amplifer was spefically made to work with the TA-E9000ES WHEN IT WAS ORIGANLY PRODUCED
Here's a page for the 1st one
http://home.online.no/~espen-b/ta-e9000es/
It will work with your 7.1 receiver. Just use one of the inputs on the 7.1 to connect to the Pre-amp
PLease rate my help if this helps
Thanks
Nov 04, 2009 | Sony TA-E9000ES Amplifier
No sound to speakers but it does power up
try to connect all your cables again but step by step and make sure you connect it in the right way and correct location of every cable.
Oct 05, 2009 | Sony TA-E9000ES Amplifier
Power on but no led display
"Power board:
The power supply is the main culprit for most of the TA-E9000ES failures. Symptoms of this are no sound and a very dim or no display. Apparently the power board has several weaknesses which have caused Sony to supply a modified version in later production units. The circuit around transistors Q108 and Q109 are prone to oscillation, which will cause one or both transistors to break down, as well as resistor R124. This resistor is originally a surface mounted device capable of 1/10 watts of heat dissipation. The modification suggested by Sony is to replace this 4.7 k ohm resistor with a 1 watt rated version. Also, to prevent further oscillations a 100 pF capacitor is added in parallell with R153. (Some suggests that also transistor Q110 is a candidate for replacement.) The US issued service bulletin from Sony suggest that this fault may occur with units having a serial number in the range 800001 - 802746.
Serial numbers 80#### are for the US/Canadian version.
Serial numbers 50#### are for the european version."
http://home.online.no/~espen-b/ta-e9000es/#faults
Aug 26, 2008 | Sony TA-E9000ES Amplifier
Zone B of Sony amplifer seems to have stopped sending most of signal
Hi, please have a look at your supply. The voltage might have gone below 21V on your newer models and 42V on your older models. This you will find near the pre-amp. Look for 2 big Cap's and start from there.
May 27, 2008 | Sony TA-E9000ES Amplifier
TA-N9000ES Amp - Standby light constantly blinks - no sound
The flashing light is indicating that a fault has been detected, and it is staying in "protect mode". First disconnect all cables from the processor (except the power cord) and then power up the processor. This will eliminate the possibility of a shorted cable or a problem with any connected components. f the light still flashes, there is an internal problem and the processor will require profesional service.
Oct 09, 2007 | Sony TA-E9000ES Amplifier
Sony TA-E9000ES Amplifier Logo
109 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
