Question about Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
Need to know how to adjust pressure regulator for low/high limits
This is for a type 30 ingersoll-rand compressor.does not want to cycle on/off like it should
    President:
  • 583 Answers
Sorry to be contradictory here, but better not to mislead or scare someone... Thepressure relief valve has absolutly nothing to do with cut in cut out pressure settings.the pressure relief valve is abrass fitting on the outside of the tank hexagonal fitting with a thin shaft coming out of the centre normaly with a ring on it not unlike akey ring .THAT is a blow off valve a safety device, that long before the air pressure is too great for the tank,will blow offthe air pressure in the tank ,try it, grab the ring and pull it out and it will dis charge any air in the tank ,that ios what it will do if thair is too great in the tank.. tanks are pressure tested and the appropriate valve fitted. NOW FOR YOUR ORIGINAL PROBLEM .you will find a control box ,useualy black or dark brown bakerlite cover,the electric cord goes into it ,also there will be another electric cord coming out and going to the electric motor that drives the compressor . If you take the cover off this you will find the cut in and cut out adjustments that allow you to set the cut in and cut out pressure as high or low as you want,that is whith in the capascity of the unit.It is self explanitory and there will be ( or should be ) instructions inside the cover .If you have any difficulty come back to me preferably with themotor and compressor sizes and i will walk you through it NOW AS MUCH AS THIS GOES AGAINST THE GRAIN, SHAG79 IT WOULD BE FAR BETTER IF YOU KNEW A BIT MORE ABOUT THE THINGS YOU ARE ADVISING THEM ABOUT EXPLOSIONS AND DEATH !!! WHAT ARE YOU-----A ******???
Posted on Aug 13, 2009
    Problem Solver:
  • 7 Answers
There should be a pipe leading from the tank to a box that looks like a water pump pressure regulator.
If the compressor does not turn off when the tank pressure reaches the preset limit and if the safety fails the unit may explode. I would replace the regulator with another. Some things are just not worth saving. the regulator can be fixed but if the compressor explodes serious damage and or death may result. I think I would go to your dealer and request another switch (regulator).....!
shag79
Posted on Nov 24, 2008
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
Tank Pressure Regulator Safety Valve is activating every 15 minutes, how to adjust pressure in tank as a first step. May be a problem with the regulator. Can anyone help or suggest a fix other then buying...
Hi jerry, my name is John. Welcome to FixYa. Your talking about your pressure switch. First tell me is your tank building up to say 130psi to 120psi? Let me know and we can go from there. .......I will post it here...........John
Dec 02, 2010 | Ingersoll Rand 2475N75 Type 30 2Stage Air...
Whats the problem when the relief valve on the low pressure side is passing?
pull the head and inspect your intake exhaust valves most likely have a bad valve in the high pressure side
Oct 19, 2010 | Ingersoll Rand - Rand Type - 30...
I just bought a used ingersoll rand ss3L3 and need to know how to adjust the pressure regulator switch. Also how to set the high and low limits.
if you want more pressure out your hose use the outlet pressure regulator. if you want more or less air put in the tank you can try to adjust the pressure switch. different models are adusted in different ways. there may be a screw between the points that make contact. adjust it up or down to see the direction you need to go. some of these switches won't let you adjust or id they do it won't be much.
Sep 02, 2010 | Ingersoll Rand Single Stage Electric...
Need to set low level on my compressor
That would depend on the type of pressure control switch it had on it, but all of the ones I've ever seen have it near the high pressure adjuster under the pressure switch cover- VERY HIGH VOLTAGES- RISK OF INJURY OR DEATH- UNDER PRESSURE SWITCH COVER WITH UNIT STILL CONNECTED TO POWER-
On the common switch used (A condore mdr 5) the differential is adjusted by DEPRESSING the nob & turning it.
On MDR 4 the adjuster is directly behind the high pressure adjuster. it is a flat bladed screw attached to a spring-screw in to increase cut in pressure.
You can also get pressure switches with a higher cut in pressure.
In Australia from a company called Ross Brown Sales in N.S.W
Hope this helps
Regards Andrew
Jul 17, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
My ingersol rand compressor shuts down on low unload sump
check minimum pressure check valve on top of separator cover.
Jun 30, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
Adjusting the pressure on the 2340-E
most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle
Oct 29, 2009 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
Compressor short cycles during operation. (load / unload). hose to guage and pressure switch ok. what could be the problem?
The pressure switch has an adjustment for the low pressure cut in and the high pressure cut out. If the pressure range is set too close the cycles will be short. You need to work out which setting is wrong by looking at the pressure guage when it is cycling and adjust the pressure switch accordingly.
Sep 06, 2009 | Ingersoll Rand UP6-30-125 120 Gallon...
Ingersoll Rand  Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage  Logo
1,887 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
