Question about Motorola Mobility Earwrap Handsfree For RAZR V3, PEBL U6, SLVR L6, SLVR L7 Headset
Motorola l6 phone, on orange, keeps displaying the ''insert sim' error.
This happens when the sim card is in place, and the connection seems fine. but usualy occurs if when i turn my phone on.
I was having the same problem, when u place the sims card in the slot, make sure the little metal clip is slid up over the sims card to insure connection. I didnt realize at the time i was suppose to slid the that clip over the edge of the card. As soon as i did this it worked fine.
Posted on Jan 17, 2007
Issue solved ....soln rocks ............
Posted on Aug 28, 2008
SOURCE:
Insert sim error in motorola l6
This error is not caused by any phone's internal error of failure. It is commonly a message given by the phone that the Sim is not connected correctly. In this case, first make sure the Sim is inserted correctly and fixed firmly into the slot. Also make sure that the Sim is fixed with the Metal Slot on the top to ensure total connection of the Sim with the phone. Try the above steps and reply me.
Thank you Sir, Have a nice day.
Sep 26, 2009 | Motorola Mobility L6 Cellular Phone
How do you insert sim card
on the top there is a sivler (usually) thing you push and it unlocks the back.
Aug 18, 2009 | Motorola Mobility L6 Cellular Phone
Problem with sim card
try to check the sim card socket "the 6 pins" if the settings are level, it there is one ore more that are dislocate just lift it up, and if the problem still the same, try o check the power IC
Apr 15, 2009 | Motorola Mobility L6 Cellular Phone
Razr says insert SIM
yeh it seems that ur sim card is no more working. it happens sometimes instantly. u have to use a duplicate sim of the same #. if u want to keep this #.
Jul 22, 2008 | Motorola Mobility RAZR V3
Phone problems
I have had a new orange sim card for my SonyE W850i, however the new sim card isnt connecting to the phone (i think). I have noticed that the new sim card has a smaller 'chip?' on it. Could this be the problem. I have tested both the phone and the sim card on phones/ sims and they seem to work fine, just not when they are together. It seems as though they are incompatible (the phone is an orange make so there should be no problems there). The phone sometimes reads 'insert sim'. athough other times it works ok but then for no reason it breaks down to 'insert sim' again.
Mar 09, 2008 | Sony Ericsson W850i Cellular Phone
Insert sim
Try cleaning the sim card slot of the L6 with a pencil eraser, then cleaning it out with cloth. After that you can try again, if it still says insert sim, then you might need to reformat or reflash it, bring it to a mobile phone technician...
Dec 10, 2007 | Motorola Mobility L6 Cellular Phone
Motorola l6
hai friend it is a simple problem to solve
just do unlock u r phone with help of unlock saftwere......
Dec 02, 2007 | Motorola Mobility L6 Cellular Phone
L6 bought off ebay "insert sim"
hi there try cleaning the terminal contacts of your sim and also on the phone. or maybe your sim card bends a little try flatten it slowly. if not your phone has a hardware problem. must go to nearest service center to repair that.
peace!
Nov 26, 2007 | Motorola Mobility L6 Cellular Phone
Unlocking procedure
I think you need to insert the original Sim card that was used when you set the code.  The code is stored in the card. Once you have done that and unlocked the phone, the phone will work with all other Sim cards.  Just remember if you set the code you have to use the card that was in use at the time.
You can take the phone to a shop and they might be able to clear it.  They have special software for that purpose, that isn't readily available to all.
Oct 31, 2007 | Motorola Mobility L6 Cellular Phone
Cellular phone doesnt recognize SIM after it got wet
dear it happen when mostly connection of sim module is cut of check the connection.
Mar 09, 2007 | Samsung SGH-e317
Motorola Mobility Earwrap Handsfree For RAZR V3, PEBL U6, SLVR L6, SLVR L7 Headset Logo
424 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
