Question about Zebra LP 2844 Thermal Printer
Missing Line In LP 2844 Thermal Print
If I print a pure black box from my printer there is a single white line down the middle as if the printer is not printing there?
I have tried a cleaning strip to no avail?
Can anyone offer a suggestion as to how I can rectify this problem?
Thanks
I would agree with Starblazer, it's either a failed element (in the printhead) of dirt building up on the printhead. If you cannot see any debris on the printhead then it is most likely a filaed element and you will have to replace the printhead.
Posted on Jan 02, 2009
Defective or dirty print head.
Posted on Dec 02, 2008
Hi, i have a TLP 2844 printer Thermal, but i cant print labels. I have read the manual and follow the instructions. Every time i put labels on the printer, only send me blanks. Can you help me, please
Are you trying to print in thermal or thermal transfer mode? If thermal transfer mode, do you have the ribbon install correctly with the coated side facing towards the label? If using thermal mode, are you using thermal paper and are you trying to print on the coated side? Hold the feed button down and turn the printer on. Hold it down until the light stops flashing. At this point the printer will print a diagnostic dump. If nothing prints then either you have the media loaded wrong or something else is wrong with the printer.
Jul 19, 2011 | Zebra LP 2844 Thermal Printer
MY ZEBRA LP 2844-Z IS PRINTING BLANK, WHAT COULD BE THE PROBLEM?
Since the LP2844 is a direct thermal printer, the first thing to check is to make sure you have direct thermal labels - regular label stock won't work. Just quickly scrape your thumbnail across the label, the friction will cause a black line if the label is direct thermal.
Aug 11, 2010 | Zebra LP 2844-Z Thermal Label Printer
Light Printing on a Zebra 2844
You will know when the printhead is starting to wear out by seeing white vertical lines. The line is a "void" area caused by an element/elements that are worn away - no image is being produced. Darkness is usually controlled by the printer driver and/or the label software being used.
Apr 22, 2010 | Zebra LP 2844 Thermal Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My lp 2844 will not print
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Apr 05, 2009 | Zebra LP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra Thermal 2844 prints text poorly
Lizardlick,
I found this information in the user manual:
Let the print head to cool for one minute, then use a new
cleaning pen to swab the print elements (the thin gray
line on the print head) from end to end. NOTE: You do
not have to turn off the printer to do this.
If print quality remains poor after cleaning, try the
Save-a-Print Head cleaning film to remove buildup
without damaging the print head. Call your authorized
reseller for more information.
Mar 31, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
369 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
