Question about Whirlpool RBD245PD Electric Double Oven
Whirlpool Double over
Was self cleaning my upper over yesterday and during the cleaning process all my functions stopped working, no clock, nothing and the door to the oven is locked and cannot get it open. I have tried the ciruit breaker and that has not helped. Does anyone have any suggestions.
  • 2 more comments
  • Anonymous Dec 16, 2007
    Whirlpool model #RBD275PDQ. (27" and not 24") Same problem. In the self-cleaning mode the total oven shut down. The upper door stayed locked. This was probably only the 4th time I did the self clean in the 9 years or so since I had the total kitchen re-done. For $258 the repair guy got the bottom unit working but the upper is still dead. He said for another $400 or so we can have the whole thing working again! Ouch! Though far past any warranty period, paying almost $700 to get it back running is an outrage!
  • Anonymous Dec 23, 2007
    Exact same problem. Stay away from Whirlpool. I sure will.
  • Anonymous Feb 11, 2008
    My issue sounds exactly like the one listed. I was self cleaning when about half way through the process the oven had a total system failure. There was no display, so I checked my circuit breaker, at the box. It wasn't tripped. Now I have an oven that doesn't work, and I cannot get the oven door open. Ugh! I will be calling Whirlpool to express my concerns!
    Ps., at the time of this email, the cost of the TCO was only $42.13.
  • Anonymous Feb 18, 2008
    We also had our oven shut down completely. It was the second time we had cleaned the oven.. My daughter, in the cool down cycle,pressed the off button.
    Also when turning ON the bottom OVEN to use both at the same time they would both go warm and never heat-up. We never had the use, of two ovens from the begining. We thought it was age of our home,finally had everything checked out and we had enough power to the unit.
    Our oven also locked up!
    We took in the fuse in the back of the unit/ it checked fine.We had two re-pairmen from the same repair shop come out.( after 3 1/2 hours and two days. The cost was expected to be close to 500.00)
    They after changing a small fuse above the door latch and behind the clock. Once the front panel was changed we had a digital reading. Before we had no reading of clock or otherwise showing , this prevents the showing of error to a repair person. The power strip that connects the front panel was bent in instalation it seem to have been bent as it was cracked. We orderd a new front panel includes plastic trip and had it installed $ 132.00. We did not the green computer one ($220.00)attached and it works. The latch is magenetised and can easily be put in place it is also above and behind the panel.We are baking up a strorm and the bottom oven even works now!!! All due to the front panel! Which can be orderd with the model #. The model # is on the inner door of the oven. Always remember any time handle- Turn off power to appliances.
    We had a small fuse above the latch, and the front panel changed and now have the use of both ovens! Finally sucess ! I was disapointing to think we got a lemon. But now I am in great hope of a Thankgiving dinner and usuing both ovens at the same time.
    President:
  • 878 Answers
Big dib, the TC0, ( thermal cut out) probably has opened. This is non resetable. To get at it you have to pull the oven out to a point where you can get at the back. Then you have to remove the oven back panel and there is the TCO. Part number 4450249. You can verify this by ohming out the TC0, if it shows open (no continuity) it's bad. I have done a number of these and it takes two people to repair it safely. Kill the breaker when going in there. Catriver..post back.
Posted on Dec 30, 2006
Whirlpool RBD245PDB6 went dead and locked up during self cleaning. It was the third or fourth time in 8 years we used self cleaning. The TCO in the back was open, replaced it but still inoperative. I found a thermal limit fuse in line on the black wire leading to the printed circuit board. It too was open, after replacing it the oven works fine. Check both fuses.
Posted on Jan 30, 2008
6-e f-2
Posted on Mar 14, 2007
This problem is chronic with this oven. Complain as loudly as you can to Whirlpool. It won't do any good, but they should know that there are more than just a few of us out there who are dissatisfied with their product.
Control board is blank - door is locked
The cavity thermal fuse has blown if this happen during a self clean the TOD for the upper or lower oven has blown
Jul 31, 2014 | Whirlpool RBD245PRS 24" Double Electric...
The panel went black- no display of clock, temp, etc. The oven doesn't heat up. the light weorks inside the oven
Hello, and sorry to read about your problem.
if you have tried to re-power the unit, and still have the same issue, you then have a general main board failure,
you may want to contact a service company. it takes experience to know which part is defective.
I tried to help you. Please help me and vote/rate my response thanks.
Jan 01, 2011 | Whirlpool RBD245PD Electric Double Oven
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
We had a power outage today during the self cleaning process of our double oven.. The Electronic Oven Control panel is dead. No lights of any kind. The circuit breaker is ok. Upper door is locked.
Turn the breaker off for 5 minutes. this will reset the system. If you still have no power then it spiked your control board and it's the board that is fried.
Please remember to leave rating before you sign off
Dec 20, 2008 | Whirlpool GBD307PDS Electric Double Oven
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
Whirlpool RBD245PD Electric Double Oven Logo
534 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
