Question about Dewalt D51825 Heavy Duty 31 Degree Clipped Head Framing Nailer
Nailer leaking air
Hey there,
I have had a Dewalt d51825 frame nailer for a week, worked awesome, set it down working on Friday, went to use it today and it won't fire and bypassses air through the trigger when pushed. Took it apart and checked the o rings, seemed to look okay, any suggestions?
Thanks
Mike
Same situation here with the same model.  Turned out to be lack of pressure coming from the air compressor.  I turned up the pressure a little and things went fine afterwards.
Posted on Feb 14, 2009
  • 65 Answers
Replace o rings and check driver for debris ore burrs these can be removed by light stoning
Posted on Dec 03, 2008
Dewalt won't return piston
If you have proper air pressure and it wont return it needs attention to the O rings. You might try a squirt of 3in1 oil if oil is compatible with this gun.
Sep 07, 2013 | Dewalt D51825 31 Clipped Head Framing...
I need a owners manual for Dewalt D51825 nailer
Here is a site that has you manual. https://www.manualowl.com/p/Dewalt/D51825/Manual/182055
Jul 12, 2012 | Dewalt D51825 Heavy Duty 31 Degree Clipped...
DeWalt D51822 Framing Nailer: Replaced the trigger valve and air is still coming from the nose of the gun. I would think no air should get past the trigger valve until pressed. What's wrong?
Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer. Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. Good luck with your repair
Jul 05, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt D51850 framing nailer leaks air continuously
You could have broken internal parts but more likely you have broken or worn o-rings inside the nailer. You can go to the Dewalt service site at, http://servicenet.dewalt.com/, search for your model number and get a good breakdown of the nailer and order the parts you need to rebuild it. If you replace any o-rings, replace all of them.
May 25, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
Just got a Dewalt D51825 Framing Nailer that takes 2" - 3 1/2", 30 - 34 degree paper collated clipped head nails. What is the best source for these nails, including recommended brand? Will it...
Your nailer uses a very common and lowest price nail when using bright nails. Other varieties are expensive, stainless, twisted, galvanized, so if you are a big user not a problem. I on the other-hand do not use very many nails in a years time. A case of nails will last couple of years. A box of stainless or galvanized will be an expensive proposition. Because of the weight of case of nails, shipping is very expensive unless you find speicals. At www.toolbarn.com , you will get free shipping for orders of $200 (less than 70lbs). Best bet is to find local dealers, and right now because of the economy, special pricing. Look for deals on broken cases of nails. I usually find broken/open cases of nails at Lowes for half price. Buy what ever you come accross that is a good price because nails have a long shelf life if you can keep them dry. Good holiday
Dec 29, 2010 | Dewalt Clipped Head Framing Nailer
As I try to fire the gun, I just get a small thump of air and no nail fires This gun is 2 years old and worked perfectly when I put it away last spring.
Problem you describe is typical of stuck driver or firing valve. Easy to check; remove head and make sure piston moves down cylinder (upon removing head, piston should be at top). Your gun utilizes sliding cylinder instead of moving valve in head. When you pull the trigger the cylinder moves down allowing air pressure to drive piston down. Orings swell overtime which prevents the cylinder from moving/firing. If cylinder does not move down/up, may be time for rebuild kit. Parts are available at dewalt service center or can be ordered from www.toolpartsdirect.com. Good luck
Aug 30, 2010 | Dewalt D51825 Heavy Duty 31 Degree Clipped...
DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Jun 13, 2009 | Dewalt Round Head Framing Nailer D51845
Dewalt D51825 Heavy Duty 31 Degree Clipped Head Framing Nailer Logo
197 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
