Question about Olympus Camedia D-425 / C-170 Digital Camera
How do I increase the dpi setting on my Olympus D-425?
The default setting seems to be 72 dpi, but I would like the image to be 200 dpi. I haven't been able to find anything that tells me if I can change this setting and, if so, how to do it.
    President:
  • 919 Answers
Unfortunately most of the Olympus cameras shoot at 72 dpi by default - a suggestion is to shoot at the highest quality setting and then use Adobe Photoshop to modify to 200 dpi if that's what you need.
Posted on Dec 11, 2008
72 dpi instead of 300dpi
You do this in your editor. In photoshop you go Image -> Image Size and you'll see resolution set at 300 as default just change the 300 to 72.
Apr 25, 2016 | Canon EOS 60D Digital Camera
Can I change 70 dpi to 300 dpi in my canon 60d camera?
Apr 25, 2016 | Canon Cameras
My samsung gt-c3530 mobile does not show jpg images copied from my laptop. what could be the problem
As this handset is an old model you need to check the manual for the supported file format, and resolution support. You can check the DNS settings from your service provider.
May 02, 2011 | Samsung SGH-a437 Cellular Phone
My samsung phone gt c 3530..am not able to open any jpg images ..please help asap..
this is bcoz image dpi is more than 72 (for me it is 96 ) so convert it to 72 or less it will open even default camera takes image with 72 dpi
i converted to 72 dpi using Adobe Photoshop
Apr 18, 2011 | Samsung SGH-a437 Cellular Phone
Images taken by Sony DSC-W200 camera are only 72 DPI.
Pictures on a digital storage don't have any DPI. You get DPI when feeding the pictures into an output device, that is, you can put a ruler on it and measure it. Unfortunately JPG does have DPI tags. I don't know, what these tags try to tell us. With tag editors any value can be put into these tags without any visible effect. Non-displayed pictures are measured in Pixels (width x height).
Oct 19, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Want Increase resolution from 72dpi to 200 dpi
increase in dpi will not increase the resolution. dpi = dots per inch for example you have a res of 1024x768 at 72dpi you get a printed image of 14.2x10.6 inch at 300dpi you get a printed image of 3.4x2.5 inch
only thing possible is to interpolate the image. but thats **** in my opinion.
Jul 23, 2009 | Fuji Finepix S5800 Digital Camera
I have a text image in cursive writing. the image size is 72 DPI. I need a way through which i can run this text image & get good 90% to 100% accuracy over transformed text. The problem is whenever i run...
Hello strivastav_p,
It sounds like you are attempting to increase the size of the image. You can do this, but you will always lose resolution. 72 DPI is 72 DPI. It cannot be increased to 300 DPI. Think of it like this:
You have 72 pieces of candy that fit in a small box made to hold 72 pieces of candy, and it looks like you have lots of candy.
Now, you get a big box that can hold 300 pieces of candy and put the same 72 pieces of candy in it. It no longer will look like you have a lot of candy.
Image resolution works the same way. The only way to get the text to be clearer is to scan another copy of it at 300DPI and then do what you need to with it.
Hope this helps!
Jeff
If this response answered your question, please rate it. Thank you!
Mar 12, 2009 | Computers & Internet
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic DMC-TZ3 72 dpi problem
Sounds like Photoshop's setting, or default setting, is to import picture at its maximum size. If you RESIZE pic on Photoshop, it shoud automatically increase DPI while reducing physical size.
The other thing to be aware, TZ3 defaults to a certain jpg compression. You can minimize compression of data with settings options on TZ3, but I doubt this has anything to do with your PhotoShop issue.
Also, in SIMPLE mode you can select a physical size for photo, even after pic is taken(resize), on camera.
Hopes this helps.
May 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
DPI
Have you looked at the number of inches that 72 dpi is spread out over? 72 dpi is the standard default setting for any digital camera. What matters is the size that you actually print it at.
Sep 07, 2005 | Panasonic Lumix DMC-FZ3 Digital Camera
Olympus Camedia D-425 / C-170 Digital Camera Logo
412 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
