Question about Dryers
Kenmore dryer my dryer tumbles, but there is no heat. please let me know what could be wrong.
  • 5,911 Answers
The following link will give you some common advice for a dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, check your receptacle power to ensure you have the proper voltage. Then, I would recommend you check and clean your dryer ventilation ducting. Clogged ducting is the number one contributor to dryer heat related problems. If a dryer is left in a clogged condition, any replaced components will fail again. Most commonly, the Thermal Cut-Out (TCO) will fail first. It is designed to protect the heating element in an overheat condition. I'm not saying this is your fault, as you will need to check all the components listed to rule out all possibilities.
Read through the link provided and let me know if you need further assistance. I hope you find this information helpful.
NOTE: If the TCO is found to be defective, replace the Hi-Limit Thermostat as well. Often, these two parts are sold as a set. Failure to do so, may lead to premature failure of either component.
Posted on Nov 24, 2008
Kenmore Gas Dryer 11072212101 won't heat. we
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
Kenmore elite model 11070092990 dryer tumbling but not heating unplugged and started again-still not drying
heatman101
Jun 13, 2011 | Kenmore Dryers
My gas dryer won't tumble or heat
sounds like a few things are wrong/ needs checked, will not tumble is usually the belt, no heat is usually a thermal fuse if the pilot light is lit. Here is a website that will assist you Tim:
http://www.applianceaid.com/gas_dryer.html#noheat
May 15, 2011 | Kenmore Dryers
Kenmore HE4t gas dryer will not heat. One load
The Sensor for heating element cut-off is bad. It wrongly detects the unit is overheated so it signals to inhibit the gas valve not to open. Since it is not opened, gas is not burnt through the manifold hence not heat why the machine is tumbling. Good luck.
Apr 18, 2010 | Dryers
I have a Kenmore electric dryer 68721 that doesn't heat. It cycles and tumbles.
Most likely you have a bad heating element or a bad wire/connection. The only way to test is with the cabinet open and the dryer running. I would recommend that only a qualified person or tech perform this. I hope this helps. If I can t anything else to help please let me know.
Mar 21, 2010 | Kenmore 64742 Electric Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Does not spin/tumble
IT IS POSSIBLE THAT YOUR DRUM SUPPORT & BEARINGS HAVE GONE, WAS IT SQUEEKING & HAS DRUM DROPPED SLIGHTLY??
IF SO ID SAY THAT IT IS THIS MINE WENT WRONG A FEW MONTHS AGO, SO I TOOK IT TO BITS & IT WAS THE ABOVE PROBLEM, JUST AN IDEA OR YOUR MOTOR HAS PACKED UP, OR YOUR DRUM BELT HAS SNAPPED..
May 22, 2009 | Dryers
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Dryer heats but does not tumble.
Yes, it is possible that the drum belt is broken.
Please rate this a FixYa
Jan 31, 2009 | Kenmore 74642 Gas Dryer
Dryers Logo
Top Dryers Experts
