Question about Whirlpool LER4634J Electric Dryer
Element heats up... but does nothing else
I have a LEQ9030PQO, When you turn it on the heating element heats up, but will do nothing else. Could the on/off switch be defective? I took off the switch and sandpapered the terminals, but nothing.
thanks.
Steve
    Problem Solver:
  • 10 Answers
Steve,
Sounds like it is the motor gone bad. You are getting power to everything else. as a last ditch effort try testing the continuity of the wiring from and thru your push on switch to your motor.
If that checks "ok" then you may have to replace the motor.
Posted on Dec 19, 2008
We can't get our hot tub to heat. The heater light comes on but the heater still won't heat.
heating elements are resistors that get hot
one end will have 115 volts but the other end should be considerable less because the resistance of the heating element drops the voltage
if you used a ohm meter you should be reading a resistance of 500-1000 ohms for a good heater element but with your readings , there will be no resistance so the element is faulty
Apr 06, 2017 | Element Water Heaters
We have a JennAire model CP220W-C01 cooktop. We use the old coil type heating elements. There was a flash and smoke from the right front element. A repairperson replaced the connector, only to have it blow...
Unplug the element from the receptacle and then disconnect the receptacle from the point where it plugs into the stove. Now, carefully, turn on power to this heating element. If nothing happens then you have removed the likelihood of a problem in the large portion of the stove's wiring. Next, plug the receptacle cable back into the stove without connecting the heating element. Again, carefully turn on the power to the heating element in question. If there is no spark then the cable, connector and receptacle are ok. If it does spark, replace the receptacle and cable assembly. No spark, then inspect the heating element where it connects to the receptacle. Look for melting or signs of damaged insulation that would allow for a "dead short". If you see damage to the element then replace the element. No damage, clean the connections with a toothbrush, and plug the element back in and turn on the juice. If it sparks again, replace the element. Good luck and be careful. Don't attempt any of this if you are inexperienced in working with electricity. 220 Volts can cause death or serious injury... just the flash from an arc can cause blindness and burns.
Nov 05, 2013 | Jenn-Air Cooktops
The heating is not working.changed fuse,still nothing
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 19, 2011 | Heating & Cooling
I have a heating and air unit. the air conditioner works and the fan will work. but when i turn on the heater it will not ignite. i have checked the thermostat and it sends the signal to the unit to turn...
To get proper heat, keep your temp setting at 30+ degreeand also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.It it's with RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 13, 2011 | Heating & Cooling
The heat control valve appears to have stuck, the water is only luke warm
I do not know what heat control valve you are referring to on an electric water heater. On an electric water heater it has two heating elements in most cases. One at the top and one on the bottom. One of these is more than likely defective. Turn the power to the water heater off at the service panel or at a disconnect switch. Now take the covers off both heating elements. Check each one with a ohm meter to see if you have continuity. If your meter reads nothing that heating element is bad and needs replacing. On each heating element is a thermostat to set the temperature. Set the upper element to 120 degrees and the lower element to 130 degrees.
Jan 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Nothing on the oven works, however the burners work on top, but when we turn the oven on nothing happens I even grabbed hold of the heating element in the stove and felt no heat or burn myself or anything
Check the thermal fuses / sensors mounted on the top exterior of the heating chamber and also the heating element. Both accessible from the rear of the oven. The element is most likely to have gone. It will be a 2 or 3 turn coil type with the fan mounted to the middle of it or a flat element with no fan. You will need to check the number of turns of the coiled element and also the mounting holes to ensure you get the right type. Turn off the mains power at the breaker or distribution point. You can get to the element behind the rear plate of the oven cavity by removing the side shelf slides, and rear panel by undoing the securing screws on the plate (2 or 4 depending on the exact model you have). Often a good idea to take a photo of the element mounting and take the model and serial no of the oven so that you can take this to the domestic appliance shop or email it to an online supplier to make sure that the element they supply is correct for your exact oven.
Nov 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Dryer heats up, but acts like the motor isn't turning
POOR AIR FLOW IS YOUR PROBLEM THAT IT /// DOES THE DRUM MOVE
Nov 23, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryer turns on doesnt dry
Suspect heating element or thermal fuse. The heating element and fuse can be checked with an ohm meter. The reading should be 0-2 ohms on both devices. If heating element reads infinity (nothing) replace heating element and fuse. If the fuse reads infinity then replace the fuse.
Jan 06, 2008 | Maytag Performa PAV2200
Whirlpool LER4634J Electric Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
