Question about GE Profile Harmony DPGT750GC Gas Dryer
My GE dryer will not heat up after flood damage
My basement flooded adout 3 1/2 feet and after the flood, my dryer would not heat up, after dyring out all of the water, it still want heat up.
  • rogerbarcus Dec 17, 2008
    Basement was flooded 14" of water for a few weeks to top of toilet. (we replaced the furnace motor and board and it's ok now) I cleaned the water heater and it works but washer and dryer need repair too. There is a click when I push the start button on the Kenmore fairly new dryer. I have it apart and wonder what I need to repair/clean/replace to get it going again. I have yet to start on the Maytag front loader washer.
    Thanks!
    Rogerbarcus@comcast.net
  • mikeys003 Jan 12, 2009
    I just read solution # 2 and tested it out. I have a GE Harmony Gas dryer. The dryer will trun on and work it just will not heat up. The blower usually will kick on with the first minute however its not coming on at all. Its did this about a month ago and then one day out of the blue it started working again. Here I am a month later and the Blower will not turn on. Is there any way this can be somthing that I can fix myself?
    Scholar:
  • 111 Answers
This is a Harmony dryer. The water ruined the blower motor (Harmony has two motors... one for the blower and one for the drum) The electronics are not detecting the RPMs of the blower motor. Here's how you tell. Press "HOME" then "HELP" then at the same time "MY CYCLES" and "BACK"at the same time. This will bring up the lqc test mode (technician test mode) press "START" and watch the display for Blower RPMs. if they stay low (less than 1200) morelikely in the 300-600 RPM range or lower, your blower motor is bad. Normal RPM speed would be 1600-2400 depending on your venting back-pressure.
Posted on Dec 19, 2008
  • 706 Answers
Hello chucky40,
There is a good chance that your gas valve has been damaged by the water. Can you tell if after you try starting it if the igniter comes on and/or you have gas flow to the burner? Those are the prime suspects ( albeit not the only ones) but you will need to verify these basic functions before others can be examined..
Keep me posted and I'll try to help you get thru this..
Regards,
Rick
Posted on Nov 25, 2008
We had high flood water in my basement that caused me to loose the pilot lights on bith water heater and gas dryer. I was able to relight the water heater but do not know how to relight dryer
If it's a newer dryer the lighting unit should work automatically. i have never had a dryer that had a pilot since the 1960s I would start the dryer up and see if it runs and heats up. There should be no gas if it does not light up.
Jul 07, 2018 | Water Water Heaters
DRYER GOT FLOODED- APPROX 4 INCH OF WATER - LET IT ALONE FOR 3 WEEKS DIDN'T ATTEMPT TO TURN ON OR ANYTHING - WAS JUST HOPING IT WOULD DRY OUT. TURNS ON BUT WONT STAY ON. DOES NOT TRIP THE GFI IT'S...
It's possible you have damaged the gas control valve or damaged the sensors in the heat chamber which are relatively easy to replace. They work on a safety system which will shut down all operations if they aren't performing properly, especially the gas regulator valve.
Aug 20, 2013 | GE Dryers
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Our dryer does not heat as a result of temporary flooding in basement....is there a pilot light on this model?
haven't been pilot lights for a number of years.  it could be a number of things including the ignitor, gas valve or thermal fuse.  i would start with the thermal fuse and then the ignitor..
Jul 29, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
We had a flood last night and had about 2 1/2 feet of water in basement. My Kenmore gas dry will turn on but will not heat. Is this something I can fix on my own or is the dryer now trash? thank you to...
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 19, 2010 | Dryers
No heat..we had a basement flood and dryer won't heat up.
If your dryer was under water, even if only a few inches, then the electrical parts inside it will need to dry out before you even attempt to use it. Chances are, you will have to have it serviced now or replaced completely.
Douglas
Jun 25, 2010 | Dryers
Electric dryer does not work after 6" of water from flood
The heating element is probably has water damage. Open up the bottom of the unit and see what all has been damaged by the water. If both the motor and the heating element have been damaged, you may just want to get a brand new machine.
Apr 02, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
1,712 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
