Question about Samsung RS2630SH Side by Side Refrigerator
No display panel indications on Fridge freezer
I have a similar model but UK number is RS21DPSM1/XEU. After a local power failure in the house the fridge freezer display lost all indication of temperatures ice type etc. Only a dashed green line appeared near the fridge temperatue reading. I unplugged appliance and left it for short time and then reconnected. No change. Can anyone offer a solution please
  • barneydyson Dec 31, 2007
    same problem, can you give me the location of the control board and a sorce of a new one thanks
We had the same problem due to a power surge- we pressed the power cool and power freeze buttons at the same time until it reset and it's fine now. Hope this helps!
Posted on Sep 26, 2008
  • 237 Answers
Now that sure sounds like a voltage spike took out the control board. If you can take it apart look for electrical arcing and burning, it should be visible if a strong enough surge took it out. Other than that, usually it's a swap out the board scenerio and hope it works (no real way to test the boards at home).
Posted on Dec 30, 2006
Hi, I had to turn the power off in my house and when I turned it back on the control panel/digital display is not working apart from one small flickering cursor.
Check the manual that came with the unit. From all indications there is power to the Samsung, however there is a trip device someplace (like a fused switch) that resets the controls and starts the unit up after a power failure.
If you lost the manual, go on line to Samsung for details.
Feb 04, 2018 | Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
I have a samsung twin cooling fridge model: RS21NCSV power: 230V/50Hz model code:RS21NCSV1/XEU [A] temperature is playing up!! Freezer is working no problem. The fridge is getting cold but not cold enough...
You almost certainly have a problem with either defrosting or evaporator fan motor. Please verify your model number so I can pull up your unit to provide troubleshooting information. Thank you
Mar 26, 2013 | Refrigerators
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
Freezer is always reporting an error.
The defrosting issue is normally due to a rear brd failure as this controls most of the appliance. Dependant on the model the F90% is normally indicating how much time is left on your water filter before it needs replacing.
I hope this helps
Jul 02, 2009 | Whirlpool GD2SHGX Refrigerator
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
412 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
