Question about Whirlpool Microwave Ovens
Do not understand the use of the sensor - Whirlpool Microwave Ovens
  • 108 Answers
Dear ggold
I think you refer to the steam sensor. I,ll explain how it works with one of its uses. Say you want to reheat a plate of food. You can do this two ways. You can guess how much time it will take to warm the food, and maybe not heat it enough or overcook it which can ruin some foods. Or you can just press the "reheat" button. The oven will come on at full power and continue to operate until steam begins to rise from the plate. The oven then switches to a "countdown" mode until it determines the food is hot. Saves time and guesswork. Most modern ovens work like this. Since you dont give the make and model of your oven, this is the best I can do.
Ray...
Posted on Nov 24, 2008
Have new Indesit microwave. Cannot understand manual. How do I set the length of cooking time required. (Didn't ask question clearly before)
Please contact manufacture or return unit to store where bought and get a machine that you understand the directions of operation.
Nov 26, 2015 | Indesit MWI212IX Microwave Oven
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
Cannot unlock the display panel
Elise,
So I'm understanding that the lock icon stays on no matter what you have tried. I would try pressing and holding the START/STOP button for 5-10 seconds to see if it changes. I don't know how long you've been leaving it unplugged for when you do unplug it, but i would suggest at least 3-5 minutes. If these don't work what I would do is either contact the manufacturer or maybe even a local authorized technician. This way they would be able to assist and possibly have some more suggestions or be able to find and solve the issue for you.
-Best regards-
Jan 16, 2014 | Frigidaire FFMV164LS 1.6 Cu Ft 1,000 Watt...
Black and Decker Oven
I would refer you to your owner's manual.
If for some reason you don't still have it, I'd suggest you look on the label for the manufacturer's phone number, or contact the dealer and ask for the manufacturer's contact info.
Dec 01, 2013 | Microwave Ovens
Pasquini Livia 90 Auto Espresso Machine I suspect the control unit is failing. For some time, when cold, the machine would try to fill, or run water through the brew head when switched on. A few tries and...
It does sound that you have a problem with the control of the system and could also be the sensor.
I read about a thread for pasquini products and It seems that their technical support and parts or accessories are available through this website:
http://www.1st-line.com/machines/home_mod/pasquini/livia.htm
If you would need parts or someone to go to your place and check the unit, visit the website above.
Hope this helps!
Jun 07, 2011 | Microwave Ovens
I am trying to locate the user manual for the T-Fal Sensor 3215 pressure cooker. As i saw in a web posting it is old and T-Fal no longer makes pressures cookers. That person contacted T-Fal and request...
Hello boptimystic,
I understand you need the number to contact T-Fal. Here is the number and hours of operation:
Call us at 800-395-8325 or send us a note.
Call center hours are Monday to Friday 8:30am to 5:30pm
Apr 25, 2011 | Microwave Ovens
F1 keeps coming up in oven mode
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
@#@EWR
Feb 14, 2010 | GE Advantium 120 Convection/Microwave Oven
My advantium microwave / high speed cooking oven comes up with an error code F1 while in the middle of high speed cooking
etry$
Jan 11, 2010 | GE Advantium SCA2000B Microwave Oven
Amana ACE208 doesn't work with a message 'door'
The door latch receiver has a spring action lever (inside) that is made out of plastic and cracks or wears through. You need to remove the cover and remove the two screws holding the door latch receiver. Now you can switch the top and bottom piviot switchs, putting the top one lower and the lower one on top..make sense? you"ll understand when you see it.
Feb 26, 2008 | Amana ACE208 Convection/Microwave Oven
After preheating, the convection oven displayed F1 and did not heat further
^&^%tg
Jan 29, 2008 | Kenmore 64282 Convection/Microwave Oven
Microwave Ovens Logo
103 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
