Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips Model 60PP9202 - Picture won't come on.
When I turn on my tv, the picture does not come on. But, the "On" button has a light inside of it to indicate the TV is on. This light flashes 9 times, then pauses, then repeats the sequence over and over until I unplug the TV.
Is there a part that I need to replace?
Thank you.
  • 1 more comment
  • Anonymous Dec 06, 2008
    mind does the same thing
  • rewjr35 Jan 02, 2009
    I have the same problem.
  • TERRY BOWDEN Jan 02, 2009
    blinking red light 9 times. happened after i installed a new convergence board . ive researced the net and found a lot of people are saying its the horizontal output transistor. its on the big circuit board in the middle of your set. its about an inch in diameter with 3 small legs on it. its mounted on the side of a small metal plate. looks like there is a small belt wrapped around it.
You need to replace the bulb inside.
Posted on Dec 20, 2008
My phillips 60pp9202 has a darker pictue have been told that the bulbs need changing how many will i need
It uses 3 picture tubes and if even one is bad forget it, cost is around 400 each but this model has inside three lens for those tubes, clean the lens and see if improvement--lens cloth works fine for this.
You can access them from rear of set with back cover removed.
Nov 24, 2012 | Philips 60PP9202 60" Rear Projection...
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
No picture
Replace BOTH of your STK ICs will have part number on them they are big black ICs.
Feb 18, 2009 | Philips 60PP9202 60" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
SOUND BUT NO PICTURE
try resoldering the vertical output IC. have seen bad solder on that model make the picture tubes blank as a safety feature when vertical deflection drops out.
Mar 12, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
