Question about HP Photosmart C7180 All-In-One InkJet Printer
Can not set custom paper size in HP C7180
I have a photo card 6.25x9in and cant set to this custom size. i open the setup feature in the print dialog box, i go to features, select photo paper, main tray, portrait and in resizing options select custom. here i set the size to 6.25 x 9 in and save to that name, it says at the top " the custom paper size you have just defined will not become available for selection until you have exited and re-entered the Printing preferences/Properties. so i exit and re-enter and its not there, i cant find a work around, i've printed every size there is to try to get it to fit the paper and nothing works
  • 1 more comment
  • Anonymous Dec 29, 2008
    I have the exact same problem with my hp photosmart C4580!
  • Anonymous Jan 03, 2009
    I have the same problem with my C3180
  • sunfire27 Apr 04, 2009
    I am trying to print a document in Word using a template. When I go to print, my HP C7180 will not recognize the page size defaults and tells me my paper size is incorrect. I have gone into "Features" to choose a custom paper size, but my size will not save, 'ok' is shaded gray, and the message at the top of the dialog box says: "The custom paper size you have just defined will not become available for selection until you have exited and re-entered the Printing Preferences/Properties." I have no idea what it wants me to do!
I had to seek Help several times, and then work through the steps a few times before I learned the overly complex HP method for setting custom sizes (I never thought I would have anything good to say about Dell printers, but it was MUCH easier to set custom sizes on my old Dell than on this HP C7180).
Anyway, it sounds as though you are nearly there. After you set the size and save the name, you must click OK, then click OK in the Document Properties window. Then close any open windows, like "Document Properties" or "Print Pictures", and start over from "Pictures" or whatever photo browser you are using. Chose an image and click "Print". Under Printer, chose "C7100 series", not "...series fax". Under Paper size chose "More". Your new custom size should now be the last size listed (although, it has shown up as the first size a couple of times, ...go figure). BTW, I am using Windows Vista.
Hope this helps.
Posted on Feb 05, 2009
  • SnowAviation Apr 12, 2011
    You solution works perfectly on my C7250
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
I need to feed custom paper into my C5580. It is 8.75" x 5.75" inch cardstock for shower invitations. How do I set up to print on this paper? I keep getting the paper size mismatch error. ...
You'll need to change the paper size in the printer setup options. To do so, follow these steps:
  1. In the software application you're printing from, go to File menu and select "Print."
  2. Open the dialog box that will open the printer's properties, options, setup or preferences (name depends on the software used).
  3. Click the Features tab.
  4. Under Resizing Options in the Size drop-down list, select "More."
  5. Choose "custom paper size" to enter the dimensions of your card stock.
There are other options you may want to tweak to customize the print job for your paper type, resolution, orientation, &c., as well.
Mar 01, 2011 | HP Photosmart C5580 All-In-One InkJet...
Out of paper error
The paper settings in the print driver must match what is loaded in the product. NOTE: These changes do not change the default print settings. The print settings return to default the next time the program opens.
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
Nov 23, 2010 | HP Photosmart 8250 InkJet Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
I REPLACED MY INK CARTRIDGES. I WAS PROMPTED TO
Ignore the error and continue printing. The print job might still be acceptable even if the paper size and paper type settings are not an exact match.
  1. Press Enter on the control panel to clear the error message.
  2. Try the print job again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
    Use the HP product software, also known as the printer driver, to change the print settings for your paper size and type depending on your version of Microsoft Word.
    1. In Microsoft Word, click File , and then click Print .
    2. Make sure that your HP product is in the Name drop-down list box, and then clickProperties .
    3. Click the Features tab, or the Paper/Quality tab.
    4. Select a paper size from the Size drop-down list.If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
      1. Select Custom from the drop-down list.
      2. In the Custom Paper Size dialog box, type a name for the new custom size.
      3. In the Width and Height boxes, type the dimensions.
      4. Select the unit of measurement, and then click Save .
      5. Click OK to close the Custom Paper Size dialog box, and then click OKagain to close the Properties dialog box. NOTE: You must exit the Properties dialog box to apply your changes.
      6. Open the Properties dialog box again, and then select the new custom size from the Size drop-down list.
    5. Select the paper type.
      1. In the Paper Type or Type is drop-down list, click More .
      2. Click the desired paper type, and then click OK .
    6. Select the paper source from the Paper Source drop-down list.
    7. Change any other settings, and then click OK to close the Properties dialog box.
    8. Try the print job again.
      Paper mismatch errors occur because the printer scans the width of the paper before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper Mismatch' or 'Paper too Narrow ' error.The error message might also display when you load the correct paper, just reinstall the printer driver if above procedure does not helps. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
How do I make my printer pick up thicker paper. (Kodak Photo Paper)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You need to adjust the print setting.
1) Open Print dialog box
i) In Word 2003, click File , and then click Print
ii) In Word 2007, click the Office button and then click Print
2) Click Properties .
3) Click the Features or the Paper/Quality tab.
4) Select the paper size from the Size drop-down list.
5) From the Properties dialog box, select the paper type.
6) From the Properties dialog box, select the paper type.
i) In the Paper Type drop down list, click More .
ii) Click the desired paper type, and then click OK .
7) Select the paper source from the Paper Source drop-down list.
8) Change any other settings, and then click OK to close the Properties dialog box.
Visit this link (Adjust Paper Section):-
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01913438&cc=us&lc=en&dlc=en&product=439488
Have a nice day....do not forget to rate the solution.
Feb 19, 2010 | HP Photosmart 3210 Printer
It won't print photos correctly because it only prints part of the photos
While this may be a mechanical fault, and if so a service call is going to be required to fix it, it can frequently be caused by software settings for the printer drivers or for the software being used at the time the photo is being printed.
When you select print from the software the usual response is for the printer driver's dialog box to appear. Within that box is a radio button which is usually marked "Page Setup". Selecting that button will access settings for various paper types [which can effect the problem you are having if the wrong one is high-lighted] as well as various other feature settings which can effect the printers output.
The support website for your specific printer should have information on what settings to change to realize desired results.
In software, like Photoshop for instance, settings for image size can effect the printed end result if the settings are a mismatch between photo size selected and the photo paper being used [unless there is a "fit to paper" option checked in the aforementioned printer driver page setup dialog box]. Like having those settings set to print an eight by ten print on four by six paper, for example. These settings should be checked to make sure your selected photo print size matches the paper you are printing on.
Hope that helps.
Feb 04, 2010 | HP Photosmart C3180 All-In-One InkJet...
How do I print with diffrent paper sizes?
  1. Press the Cancel button on the product to stop the current print job, if necessary.
  2. In the software program that you are using to print, click File , and then click Print .
  3. Make sure that the appropriate product is selected.
  4. Depending on the program, click Properties , Options , Printer Setup , or Printer . The Print Properties dialog box opens.
  5. Click the Features or Print/Quality tab.
  6. In the Paper Type or Type Is drop-down list, click the appropriate paper type.
  7. In the Size or Size Is drop-down list, Click OK to save the settings.
  8. In the Print dialog box, click Print or OK to start printing.
Nov 28, 2009 | HP J3680 Officejet All In One Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Hp c4180 custom envelope size problem
Please try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01518768&cc=us&lc=en&dlc=en&product=1141647.
If not open solution center> Setting> Printer Settings> Print settings and you will find a custom option there and then create a new size and give it a name and when you print from any application you will see the new size reflection in the application( i.e Microsoft word or excel) you are trying to print from.
Good Luck
Jul 13, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C7180 All-In-One InkJet Printer Logo
2,596 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
