Question about Garmin eTrex Legend GPS Receiver
Blank screen with a black line down the middle.
I would turn my eTrex Legend on, it powers up fine and acquires the satellites. However, all of a sudden the screen goes blank and there is a thin black line on the right hand side of the screen. Any help would be appreciated. Thanks.
  • Garmin Master
  • 638 Answers
Due to a new satellite launched this year, the WAAS is affected. Disable the WAAS, go to Garmin and download the latest software version FOR THIS UNIT. Install, enable WAAS and you should be good to go.
Posted on Dec 02, 2008
Etrex Legend: approximately 5 minutes after powering up and acquiring satelite signal, the unit will go blank screen and will not respond. Powering off and restarting produces the same result. While the...
Have you recently updated your unit's software? If not, go to Garmin.com and update the firmware for your specific unit. A new satellite was launched in 2009 which has caused some problems. This might be the cause of your problem. If this doesn't solve the issue, please come back and advise. If this does solve your problem, please come back and rate our solution. Thank you.
Nov 13, 2010 | Garmin eTrex Legend GPS Receiver
Garmin Legend gets black bars on screen then goes blank ? any suggestions ? Love my legend and would like to get it fixed
A new satellite was launched which caused some of these problems. Update your unit's software and drivers via the Garmin.com website and see if this fixes the problem. Please come back and rate our solution.
Jun 07, 2010 | Garmin Etrex Legend Handheld Gps
My Garmin Etrex Legend starts up and finds the satellites, but then screen goes blank except for vertical line on the screen.Stays that way until batteries wear out. Fixable?
I have the same Garmin product. It had a problem displaying anything. I went to the Garmin web site and got tech support. They fixed the problem by telling me what to do. Try them befor you throw it away. But it sounds un-repairable
Aug 11, 2009 | Garmin Etrex Legend Handheld Gps
Problem with display
Try updating the unit's software via the Garmin website. There was a satellite launched last year which was causing this problem, and updating the unit's software fixes this. Don't forget to come back and tell us if this fix worked for you.
Jun 17, 2009 | Garmin eTrex Legend Cx GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
GPSr shuts off
Firmware needs to be upgraded on these units because the atellites are changing every so often so does the programming in these units, check to see if there is a firmware upgrade to fix these problems, the line in the middle of the screen is because it either hung during the process or the units lcd is going bad.
Apr 22, 2009 | Garmin eTrex Legend GPS Receiver
ETrex Legend display
Let us know if this solved your problem. Thanks.
Nov 22, 2008 | Garmin eTrex Legend GPS Receiver
ETrex Legend screen issue
Nov 13, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
622 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
