Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer whines any time the agitator is moving or spinning, not while filling, etc. What might this be? I live in the middle of nowhere and my appliance repair man has died of old age. Literally.
We took the housing off the washer and started the machine, albeit carefully, and followed the squeal. Sounded like the water pump thingy in the front. Took that off from the machine but still connected to the hoses and the squeal stopped. Dipped and drained machine, removed water pump thingy and looked inside. Found a really beat up hairpin/bobby pin lodged inside! (I have two teen daughters at home) Removed pin, put back together, and wah-lah, a few hundred dollar miracle, no squeal!
Posted on Nov 24, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Kenmore 417.97922701 washer tub will spin but will not agitate
Disconnect power to the unit.
Does the agitator move freely in both directions by hand?
Could be your agitator coupler needs to be replace
Also need to verify the lid switch and pressure switch are working properly. Let me know if you need further assistance
Nov 10, 2014 | Washing Machines
Will not agitate after water fill up. Motor makes whining sound.
It sounds like it could be the coupling that has worn or broke, to verify this put the washer in spin, let it drain the water out (if it will) then turn off the timer or open the lid, wait 10 seconds or so then start back up in spin. If the washer just whines then it is most likely the coupling. I have put together some instructions on this if you follow this link it will tell you more about it and how to replace it if you wish. Let me know if this helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
May 06, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have an A211 washer and it will not agitate. it fills and i can get it to spin but i cant get the middle piece to work. also, the agitator will not move by hand, it is locked.
Maytags will always spin because the whole trans turns in the spin cycle so the only thing doing any work is the motor,but when they won't agitate it is a bad transmission,if you have the old helical drive it runs $500 part # w10172458 if you have the orbital drive it runs $225 part # 22002127 they were good washers but that is a lot of money.
Sep 21, 2009 | Washing Machines
No Spin or agitation After move
Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Motor whine w/ agitation & no high speed spin
try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Mar 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal De
