Question about Fuji FinePix S5000 Digital Camera
What the ?
Well, it just won't turn on, straight and simple. It worked fine for about two months, then wouldn't power up. I haven't dropped or bumped the camera at all. I've replaced the batteries, but still nothing. if anyone has experienced this or knows of a solution besides a professional fix please fill me in. It would be gratefully appreciated.
    Champion:
  • 217 Answers
I think theres nothing you can do.. professional fix is badly needed.
Posted on Sep 08, 2007
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
I dropped my samsung galaxy s 2.. it won't power on.. the lights at the bottom come on briefly.. but the screen stays black.. I can hear it power up somtimes but the screen remains black. Can I f
Take off the cover, remove the battery and use a pencil eraser to clean both the battery plug pads and the plugs in the phone. Get a piece of thin tape and apply to the bottom of the battery and then reinsert. Try to power up. Sometimes dropping it will slightly bend the batter contacts or misalign them. Clean and see if that helps.
Jan 06, 2018 | Samsung Galaxy S II
My compaq c 581WM notebook pc won't start at all. A while ago it got pretty banged up but I got it fixed and it worked fine untill like 5 months after and from then it wouldn't charge or turn on...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 21, 2011 | Compaq Computers & Internet
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
May 31, 2011 | 2006 Pontiac G6
2004 Sante fe 3.5L 2WD went out to go to work and wouldn't turn over, (assumed dead battery), went down and got new battery and installed, still wouldn't turn over, (assumed starter shot),removed...
TEST POWER LEADS TO STARTER FOR POWER
AT STARTER (BATTERY POSITIVE TO STARTER BATTERY NEGATIVE TO ENGINE BLOCK)
THEN TEST FOR SIGNAL POWER TO SELENOIDE ON STARTER
(KEY TURNED TO START POWER SHOULD GO TO SELENOIDE)
IF NO POWER TO SIGNAL WIRE CHECK FUSES AND RELAYS
ON STARTER CIRCUIT
IF THIS CHECKS OUT MAY BE AUTO TRANSMISSION NUTRAL PARK SWITCH
TRY TO START IN NUTRAL OR WHILE SHIFTING TRUE GEARS SLOWLY WITH SHIFTER
IF STANDARED CHECK NUTRAL SAFETY SWITCH
May 08, 2011 | 2004 Hyundai Santa Fe
Won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Dec 31, 2007 | LG 42LC7D-UB Television
Phone won't turn on, took battery out and put it back in, still won't turn on, it acts like it's about to turn on and then blinks back off. Battery is charged up, I've only had it for 4 months
When you power up first let it going into off chargeing mode, then hold the power button to turn it on, continue to hold it through this whole process, then after the sitck together box has been completed (which may take a few attempets) rapidly push the right soft key until your phone jump in and out of the t-zones area which should be your default right soft key buttong then you should be able to use your phobe normally, note that it did take me a good half an hour of doing this to make my phone through the whole process. :)
Nov 04, 2007 | Samsung SCH-u340 Cellular Phone
Fuji FinePix S5000 Digital Camera Logo
46 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
