Question about Microwave Ovens
'door' message on my microwave
My microwave stopped working. There is a message that says 'door' even when the door is closed. One of the little black tabs on the door is loose. Could this be the problem? If so, how do I tighten it?
  • 1 more comment
  • sgramann Nov 23, 2008
    I should have mentioned that it is a KitchenAid Superba microwave and oven combo. Thanks!
  • sgramann Nov 24, 2008
    KEMC308KSS. Thank you so much!!!
  • William Miller
    William Miller May 11, 2010
    Please reply back with your model number so we can help you.
    Problem Solver:
  • 5 Answers
It could be a fuse. There is a large fuse behind the control panel and a smaller one on the right top side of the microwave. You have to pull the unit partially out to access this. Here is a link that directs you to a repair manual with detailed instructions how to do this.
Scroll down and find the pdf file. If it still doesn't work you may have to replace the door latch switches, one on the left and two on the right. You can find the fuses at Lowes or Home Depot. The switches have to be ordered from here:
Posted on Aug 08, 2010
  • Microwave Ovens Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would suspect a bad door switch or its mount may be loose.
Posted on Nov 25, 2008
When I open microwave oven door . close the door again light comes on an plate spins an wont stop unless I unplug it
Inside the door latch, is a safety feature, that prevents the microwave from operating unless the door is closed. This feature can easily become faulty, or even come with the fault already causing the microwave to constantly operate whenever the door is closed.
Microwaves can be very dangerous in regard to holding HEAPS of voltage within the unit. I recommend getting yourself a new microwave, as attempting repairs on any of the modern units can, more often than not, be far more costly then the price of a new one.
Hope this helps.
Apr 14, 2014 | Hamilton Beach Beach 87108 Microwave Oven
I have a Salton micorwave oven (MW-2027P). The timer works but the cook setting will not start. There is also no light on the inside when I open the door.
I had this exact same problem with my salton microwave! Even tried taking it back to the store, but with no reciept there was little they could do. Anyways try jiggling the clasps on the side of the the door, the ones that connect it to the microwave. Mind you don't jiggle too hard. Now firmly close the door, you should hear a distinct click. Now try it! The light only works when the microwave is on. The microwave won't work unless the door is closed properly and my problem was the claps were stuck! I hope this helps.
May 15, 2011 | Salton RRMW1 / RRMW1A 900 Watts Microwave...
My Panasonic Inverter S333 just suddenly stopped working. I get a "refer to manual" message. Manual has no help to offer. Even the "signal bell" sounds a little off. Up until today, it was working just...
My Panasonic Inverter S333 just suddenly stopped working April 30 after I used it for only two years, no showing in panel. It will run only when I open the door, it is strange.
Apr 19, 2010 | Panasonic NN-T694SF Microwave Oven
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
It works even if I open or close the door.
if thats a microwave.. then the sensor of the closed door is broken.. thats why it worked even when open.. and that is really dangerous...
so.. your best bet would be opening it and find the broken thing that tells the microwave when its closed...
that thing is usually the little secures attach to close the oven..
if its not a microwave, the problem might still be something similar to this..
Jan 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya:
You can find Samsung-specific parts here:
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
