Question about Winchester 12-50 x 50 Spotting Scope, Green Spotting Scopes
Adjustments do not hold and adjustment knobs don't always work.
How do I get this fixed??
  • 112 Answers
Ok im just guessing,but if you look around the outside you may see tiny holes that are filled with filler and underneath those will be set screws,with a fine screw driver you can tighten them. if not then problem is internal.good luck...larry@reichinstruments.com
Posted on Nov 28, 2008
How do I fix the vertical hold of my TV? It keeps scrolling downward.
only one of the problems with digital units they have no adjustments like old TV's
Aug 25, 2015 | RCA 20F420T 20" TV
Where is the idle screw on a 2000 R1
The following is for a 2001 model, may be the same on a 2000.
Follow your shift linkage from the foot shifter 'up' the linkage rod.
Where the linkage rod meets the shift shaft, right beside it you will find a gold colored Knob.
Thats the idle adjuster.
You will want to loosen the left Mid-fairing to allow you to get your hand behind it to reach the adjuster knob.
You dont have to remove it, just loosen the 1/4 turn screws holding it.
do not adjust the idle when the engines cold. Have it good and warmed up.
When your finished, retighten the 1/4 turn screws, and your finished.
Small adjustments, allowing the engine to 'catch-up' work best.
Good luck.
Apr 09, 2014 | 2000 Yamaha YZF-R1
How do I adjust the temperature on heat stik aquarium heater
you turn the knob - clockwise to increase, counter clockwis to decrease. Always wait at least an hour for the tank temp to reach the new setting. Only make small 1/4 turn or less) adjustments at a time
Nov 27, 2013 | Deep Blue Professionals Deep Blue Heat...
Headlights r slow or don't come up completely sometimes they do. Any adjustments ?
Make sure they are not binding.Use some lubricant and spray the hinge area.Not WD 40.I don`t believe there are any adjustments.It`s possible the motors are getting weak.But the first thing is to make sure they are working freely.Hope this helps.Good luck.
May 08, 2012 | 1990 Chevrolet Corvette
How do i find and turn up modulation
If your asking for an internal adjustment,you need to be a qualified technician to do this and the radio's schematics..which I don't know either answer to,so external adjustments would be mic gain knob,you can also gain modulation by lowering the output power knob,both can be adjusted to get the most forward swing by watching your meter swing when am or sideband transmitting.If you are using the stock mike,you could also upgrade to power mic properly wired for your radio.If you are a qualified to do so,there are online sites that have info on upgrading the modulation to this 10 meter radio by adjustments,modifications and add on parts,which does require an amateur license to operate unless modified for cb bands and only transmits on these bands..according to fcc rules.
Aug 14, 2011 | Magnum DeltaForce CB Radio
What can i do if tv's lamp no good?
This T.V. doesn't use a lamp. If you're referring to the picture tube, there is no fixing this other than making slim adjustments on the knobs on the flyback. Don't tweak it too much or it will cause retrace lines. However, in most cases a bad picture tube means its time for a new T.V.
Jun 07, 2011 | Sony KV-32FS12 32" TV
How do I change time on the MP538U? Instruction manual is no help
Hit the 'fnc' button (function) turn the control knob until you see clock adjust in the display. Press and hold the control knob until the time display blinks. To select what you want to adjust push the control knob to the right or left to select minutes hours. Push the knob up or down to make the adjustments. Exit the clock adjust function by pressing the 'fnc' button again. Here's a link to your owners manual for future problems. Have a great day and thanks for using fixya!
http://inform3.kenwoodusa.com/Manuals/kdcx592.pdf
Nov 05, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Need manual for nokia 447za computer monitor
It sounds like the edges of the video displayed are looking like they are curved in/out? I'm racking my brain trying to remember the terms used on CRT monitors and all I can come up with is elliptical? It has been awhile since I have messed with one. In any event, start pressing the buttons on the display working from left to right. You should hit the Main Menu right away. Generally speaking, there should be a factory reset function as a last choice. If you see that, highlight it and hit the accept button (it's the one you pressed to get to that screen). In the event you don't come across that, look for a Positioning choice and enter that screen. Your choices are generally a + or - for each setting. Press away on each choice increasing or decreasing until you find the correct settings you're looking for. If you're unsure of how to get out of a choice, do nothing for a few seconds and the screen will default back. Let me know if I need to clarify anything or you need a little more help. Grandkids are pesky but I've always found them worth it!
Feb 13, 2009 | Nokia Computers & Internet
Winchester 12-50 x 50 Spotting Scope, Green Spotting Scopes Logo
135 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you a Winchester Optic Expert? Answer questions, earn points and help others
