Question about RCA HD52W59 HDTV Projection Television
Picture top and bottom of programs cut off. The tops of everyones head is cut off and if watching football cannot see the score
    Problem Solver:
  • 8 Answers
I HAVE A SANYO, ON MY REMOTE CONTROL IS A BUTTON "PIX SHAPE" this will change the sides and top/bottom. I have 4 settings. OR you might check you owners manuel as to where this button is. Possibly under menu. My Dads TV is a little different from mine. so your button might not be where mine is.
Posted on Nov 23, 2008
Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Sep 21, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
My RCA 32", the picture seems to be riding up the screen.
hold menu botton in power once vol up once. vol up to76  ch top po3 aj pict size ith vol cont
Nov 30, 2008 | RCA F32650 32" TV
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Toshiba 50A50 missing sports score on top of image
Download the service manual and you'll find that there's a service mode that allows you to adjust convergence. Also, there's some adjustment knobs behind the right front speaker assembly
Oct 08, 2007 | Toshiba 50A50 50" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
