Question about Graco SnugRide - Giselle Infant Car Seat
Washed graco car seat and can't get straps back on
I washed the car seat and now i don't know how to loop the straps on
  • 2 more comments
  • jhernand Dec 31, 2008
    I took the cover off to wash, now I can't figure out how to connect the straps to the back.
  • francinabrew Jan 12, 2009
    I washed the car seat cover and I need instruction to put the straps back into the loops that fastens the car seat to the base.
  • Anonymous Apr 03, 2009
    i washed the padding and i dont know how to put straps back on
  • eleanor melvin Nov 02, 2011
    how do you replace straps
robotek
  • 1512 Answers
SOURCE: Need to Re-Assemble my Graco Snug Ride Car Seat
Hi jessibee
I found the site that you need to get an instruction manual for the seat. You will need to find the exact model of the SnugSeat that you have, because there are quite a few to choose from.
to find the model/serial number...
Car Seat trans.gif Toddler or Booster - On the back of the car seat OR on the bottom of the seat
Infant - On the back of carrier OR on the bottom of carrier OR on the stay-in-car base
Thanks for using FixYa, a Fixya rating would be great for this advice.
Good luck.
regards
robotek
Posted on May 09, 2008
SOURCE: Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
Posted on Jun 25, 2009
connorsmama
  • 20 Answers
SOURCE: I took the liner off a Graco car seat and I cannot
if it has the roll and lock tighten straps i didnt think they were suppost to come off, id call the manafacturere, or look it up on youtube
Posted on Jun 26, 2009
Fixe_You
  • 1800 Answers
SOURCE: how do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Posted on Jul 01, 2009
SOURCE: winnie the pooh graco car seat how to put the arm
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Posted on Aug 14, 2009
I recently purchased a gently used Graco travel system (counting sheep) for my house. The problem is I took it apart to clean and can't seem to get it back together correctly. Also, what holds the back...
Besides the strap in the back of the seat that I pull on or release it to go back on the red adjuster, there is a black loop on both sides of the seat that I will pull up and loop it to an indent on the plastic side arm bar
Aug 04, 2011 | Graco Baby Gear
Contecting staps on car seat
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here is the link to download Graco instructions:
http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/default.aspx?page=ProdInst
Mar 23, 2010 | Graco ComfortSport 8639 - Grey
I TOOK THE STRAPS OFF TO WASH THE CAR SEAT COVER ON MY GRACO CAR SEAT MODEL 8442CYP AND FORGOT HOW TO PUT THEM BACK TOGETHER
Hello if you have found a solution to your problem please let me know because I have the same problem...thanks
natetheneatfreak@hotmail.com
Jul 10, 2009 | Graco Nautilus 3-in 1 Car Seat
Winnie the pooh graco car seat how to put the arm straps back together after washing
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Can i wash my covers
sure, remember to only dry with a light air tumble. not extreme heat. the full heated dry will cause shrinkage.
Mar 01, 2009 | Graco ComfortSport 8639 - Grey
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
I have a Graco infant car seat and want to remove the padded seat cover to place in the laundry. There are two elastics on either side of the car seat that help secure it to the sides of the handle. I...
What model do you have?
You can call graco at: Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Ensure you do NOT wash the straps/harness, as it will make it unsafe and you will need to replace it.
They also have an online manual fi that will assist you. I checked my seat, and it is an older snug ride with no straps.
Thanks
Apr 30, 2008 | Graco SnugRide - Giselle Infant Car Seat
Graco SnugRide - Giselle Infant Car Seat Logo
1,859 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
