Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
My Kenmore side by side refrigerator is not freezing nor cooling.
Not sure how to get model number, copied these off back: 42159-054879/P50394000C0 50364/0003249175. Fridge has filtered ice/water on left side. the fan at the back of the freezer above the coils is working. I checked the Tecumseh compressor TP110AR003A8/TPD1390YXA. When the fridge isn't working, the compressor buzzes for maybe 10 seconds and then clicks off. strangely, if i leave it plugged in, every couple days the buzzing will stop and the fridge/freezer will cool again. please help, and if you can please tell me what compressors cost/installation if that's the issue, i'd appreciate it! trying to save $, am unemployed! many thanks!
    Scholar:
  • 42 Answers
Surfgl,
The model you posted does not help me much but a rough estimate would be (from Sears) about $400.00 for the compressor + about $225.00 Serv Call and Labor. Possibly another $15.00 access valve and then tax.
The problem you have is that the compressor is locking up then it may run again for a short time. It will eventually lock up and not run again. If you can prove it is (by receipt) that it is less than 5 years old, Sears will repair it free under the sealed system warranty.
The model # and serial # should be on a sticker in the top front of the ref section. If not then on the left wall or right wall top front of ref section.
If this helped please rate me good. supertechks
Posted on Nov 25, 2008
My kenmore fridge model 56723 is not cooling that is the fridge side. the fan is spinning very well but the compressor is very hot. funny enough the freezer appears to be cooling okay
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 23, 2011 | Kenmore 56723 Side by Side Refrigerator
Refrigerator stopped cooling and freezing. unpluged it for a while and it started to work again. what is the problem.
Get me the model number and make sure both fans are running inside and out side. Make sure nothing is blocking air flow below your refrigerator and inside freezer, If Sears model the number will look like 213.564897 for example. Let me Know, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Jul 06, 2009 | Kenmore Refrigerators
Kenmore side by side cold spot 4 years old just stopped cooling and freezing
Defrost problem is possibly the reason. I need to know the model number for example 213.25897 would be a way that Sears identifies their appliances. Let me know which model and we will go from there. Thanks, Sea Breeze
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Model #10657058791 freezer and fridge not cooling
Check your connections in the back make sure no wires are lose or rattled lose off of the compressor or anything like that
Feb 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Model 57572791 not cooling or freezing on either side
IF YOU LOOK INTO FREEZER BACK WALL CAN YOU SEE HEAVY FUZZY FROST?
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
438 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
