Question about Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 Series Laptop wont turn on
When the power switch is hit, the battery light flashes orange, when battery is plugged into an outlet nothing happens when the power switch is hit. The battery power reads at 25% and is ok. However processor light won't come on and laptop won't boot even to DOS. Nothing at all happens.... could this be a dead motherboard?
  • Anonymous Mar 24, 2014
    When I hit the power button it just flashes a blue led light 5 times. nothing else happens
    Sergeant:
  • 177 Answers
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Posted on Nov 24, 2008
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on....
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Mar 13, 2011 | Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
Acer Aspire One 6 Cell Battery Problem
you got a bad battery. If your old battery works fine, and the new one wont hold a charge, Take it back to the store and get another.
Dec 29, 2008 | Acer Aspire One AOA110-1626 Notebook
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
I have a laptop and there seems to be a light currently flashing orange along the front. Ive searched everywhere to find out whats happened but the laptop won't switch on at all. Its a toshiba Prestege...
The flashing light on the front of your laptop is a low battery warning. There probably isn't enough power in the battery to turn on the laptop. You need to plug in the ac power adaptor and let the battery charge until the battery light turns from 'orange', to 'green'.
May 02, 2008 | Computers & Internet
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Compaq Presario 700 470024-192 Notebook Logo
375 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
