Question about GE Profile JGS968 Gas Kitchen Range
Wolf oven explodes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}after turning on the oven( by rotating control counterclockwise),we wait about a minute and there is a mild puff sound and the oven door opensabout five inches. this is of course scarey. happening about two weeks. is theignitor the problem as with other ovens in the past, but they just didn'tignite at all? of course if it is not the ignitor i'm not going to attempt afix, nor will we turn on the oven again!
catriver
  • 878 Answers
SOURCE: Oven, Broiler inopperable
Sandwich, is it your bake or broil thats not working? You have two ignitors, one for bake and broil. One of them is your culprit. This is not a hard job. The post header says broil not working so the part number for that is WB13K0003. Bake ignitor is WB13K0004. To get at the bake ignitor you have to remove the oven bottom inside panel, remove the flame spreader (both easy). The click you are hearing is the board relay sending power to the ignitor. The ignitor has to draw so many amps to open the gas valve. The oven is pilotless. Catriver..post back.
Posted on Apr 21, 2007
Krazytech
  • 725 Answers
SOURCE: Oven not lighting
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
SOURCE: Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Posted on Aug 25, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
Obertelli
  • 3006 Answers
SOURCE: Oven Door Exploded
This fault has occurred on a number of these ovens and I've seen it happen occasionally on other makes and models.
The explosion is spectacular, but is actually due to a safety feature as all modern ovens which use glass doors must use toughened glass. This is heat-treated glass which is resistant to most knocks, but when it does break it shatters into lots of small granules instead of sharp edged shards.
In use, heat makes everything on the oven expand a little and afterwards everything cools down and returns to normal size. The problem is that the glass and metals do not expand or contract at the same rate and so there's always the chance that the differential expansion between the glass door and the metal hinges can put enough stress on the door to make it shatter. The engineers who designed your oven knew this and will have tried to ensure that the hinge design could cope, but it may be that they didn't do well enough.
The other possibility is that the door has a manufacturing fault: when toughened glass is manufactured the glass gets a lot of stress built into it (that's why it seems to explode when it breaks). After the glass has cooled down in the factory every one is supposed to undergo a couple of simple automated tests which will either cause the glass to immediately shatter or will cause it to be returned to the ovens to have the excess stresses removed. Sometimes these tests are not fully effective at identifying the "bad apples".
I'd strongly advise you to contact the manufacturer of your oven as the door should not fail in normal use even beyond the warranty period. What you have suggests a design or manufacturing fault and you may be offered a free repair without admission of liability.
Posted on Jul 03, 2009
Tip
Sign of Virus Infection
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
You can easily identify when yourcomputer system gets infected from viruses. Some of the signs of virusinfections are enlisted herewith: Computerbecomes very slow in performance.
Suddensystem crashes and computer reboots repeatedly.
Applicationsoftware crashes and random messages are displayed on the monitor.
If you find any of the above mentionedsign on your computer system, then there arises the probability of yourcomputer being infected with viruses. The next step after detecting thepresence of virus on your PC is to remove them from your system in order tosave your important data. If your computer is not infected with any type ofmalicious software then it is strongly recommended to install any bestantivirus software to keep it safe against the attacks.
on Jan 28, 2010 | Computers & Internet
Tip
Buy a TV is like when you buy a car!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When you buy a TV is like when you buy a car. You are looking for the best @ the best price. And its exactly de same you need to give itmaintenance and clean it not every week bout yes like at lease 3 months Isuggest you make some research beforeyou buy a nice DLP you need to see how much will a lamp cost and what are the problems if you buy a DLP you will defiantly need atsome point a replacement lamp. Bout remember clean you TV and any strange noise go on warranty or make some research I can gladly help on some things for theDLP’S Happy hunting for a new TV a197830.jpg ba5e86e.jpg3150202.jpg including kid's now how t buy a television..
on Jan 27, 2010 | Televison & Video
How to replace Sony Wega KFWE42S1 lamp
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How much will it be to replace my lamp?
It all depends on the type of lamp and manufacturer u has, some brands are compatible that is always a good thing.
Example:
LG, Zenith, Mitsubishi, RCA, Samsung, and some Panasonic they use. Philips so you can save money we just need to know if the model is compatible.
The cost is around $85.00 the cheap ones $114.00 Philips and like $299.00 again depends on the brand and ho is the one that sales!
There are a lot of good online stores that can send you a lamp usually for a lower price here are a few links that I can found if you need them.
http://www.discounttvlamps.com/
http://www.purelandsupply.com/
http://www.discount-merchant.com/
http://lamps4less.net/
good luck..
Apr 20, 2010 | Sony Grand WEGA KFWE42S1 TV
I have a Fridgidaire stove FE369COSE. Ran self cleaning cycle but now oven door won't unlock. Oven is cool but an error code of f9 is flashing. Does anyone have a solution? jadimin
I've had this happen with my Frigidaire stove too. The "locked" light is on.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Open the oven door and locate the light switch. Hold it in - sometimes it makes a noise and resets it.
If that doesn't work, push the Clean button and the Cancel button simultaneously and hold for about 30 seconds. The “locked” light should disappear. If it is working, you’ll hear a mechanical hum as it resets.
Apr 14, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Tip
Secret Codes For SGH-600/SGH-2100
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the secret Codes for SGH-600 / SGH 2100
  • *#06# -> Show IMEI
  • *#9999# -> Show Software Version
  • *#0837# -> Show Software Version (instructions)
  • *#0001# -> Show Serial Parameters
  • *#9125# -> Activates the smiley when charging.
  • *#9998*228# -> Battery status (capacity, voltage, temperature)
  • *#9998*246# -> Program status
  • *#9998*289# -> Change Alarm Buzzer Frequency
  • *#9998*324# -> Debug screens
  • *#9998*364# -> Watchdog
  • *#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok.
  • *#9998*427# -> Trace Watchdog
  • *#9998*523# -> Change LCD contrast - Only with version G60RL01W
  • *#9998*544# -> Jig detect
  • *#9998*636# -> Memory status
  • *#9998*746# -> SIM File Size
  • *#9998*778# -> SIM Service Table
  • *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN
  • *#9998*837# -> Software Version
  • *#9998*842# -> Test ******** - Flash the screenligth during 10 seconds and vibration activated.
  • *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected
  • *#9998*872# -> Diag
  • *#9998*947# -> Reset On Fatal Error
  • *#9998*999# -> Last/Chk
  • *#9998*9266# -> Yann debug screen (=Debug Screens?)
  • *#9998*9999# -> Software version
Enjoy. :)
on Dec 14, 2009 | Cell Phones
My wife not getting pregnant!!
my wife is prehnant but we don't want child and don't tell any one of my family so how to miscarrage
Mar 16, 2009 | Adler Royal Office Equipment & Supplies
Tv wont turn on
You have shorted transistors on deflection board just fixed one like that will have to get back to you as to where the parts are located on deflection board.
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
Placing date/time on the photo
Oddly enough Canon thought that people would only want date stamps on "Postcards". The date stamp options is only allowed when you select the "Postcard" size (1600X1200) in the function menu.
I hope this helps!
Nov 22, 2008 | Canon PowerShot A85 Digital Camera
GE Profile JGS968 Gas Kitchen Range Logo
56 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
