Question about Garden
Tiller transmittion problems.
I have a Husqvarna Tiller/650rRTT and it will not shift into reverse. It has not been used much at all. Was working great untill this happened. It still looks new. Any ideas to solve this problem. I have heard these tillers have this problem sometimes. Thanks
  • 50 Answers
Had same problem with mine. took it apart to find out i had snapped a gear shaft.
Posted on Dec 05, 2008
Transmission tiller replacement
The transmission is the main mounting point for everything else on the tiller. Everything needs to be removed from it including : engine, handle, covers, wheels, weights, etc. until you are left with the bare transmission. there will be a set of axles protruding on each side for the wheels and tines. Since replacement parts are available and you have it torn down this far you may as well open it up and see what failed. It may just be a chain, or if its been sitting for a long time and wont shift maybe cleaning and lubing the shift drum will solve your problem. Place the transmission on its side using blocks to level and stabilize it. remove all the perimeter screws, there are a few other bolts which need to be removed as well. split the halves. you will need to work around the perimeter as the seal is quite stubborn. Then inspect the inside for the failed part.
Aug 03, 2014 | Husqvarna 17" 90Torque Rear Tine Tiller
Why won't my rotor tiller stay running after starting Its a briggs and stratton
95% of run ability problems are carb related. It needs to be disassembled and cleaned. Do you leave gas in it at the end of season,if yes always drain the tank and let it run till it stops next time before storage. Good luck
Jul 08, 2014 | Husqvarna McCulloch Garden Tiller, 5hp...
Husqvarna CRT 650 Tiller gearbox is locked up
first check the linkage rods make sure that its not in forward and reverse at the same time if not you need to open it up to find the problem
Jul 25, 2012 | Garden
Husqvarna crt900 tiller wont pull or engage tines
make sure all the linkage pins are in place
Apr 04, 2012 | Honda Garden
My tiller wont go into forward gear. Reverse is fine but wont shift at all. I lubed it well and the tiller does not have a lot of use. Any suggestions.
Sounds like a problem in the gearbox if there is no external interference problems with the shift mechanism. It may require opening and inspecting the gearbox.
Jun 02, 2010 | Craftsman Rear Mount Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
What's the gas/oil ratio for CT 16 tiller
Husqvarna says 50:1
Here is a link to the break down repair manual for future use
I will send a link to the user manual when located.
Please rate this fixya solution
May 13, 2009 | Husqvarna Garden
Transmission is stuck in neural.
Possibly just linkage problem.
Mar 28, 2009 | Husqvarna Garden
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
