Question about Kenmore Elite 45986 Front Load Washer
When spining it makes very loud noise , like aeroplane when start
Hi , i have hotpoint WF000g wasching machine , the problem is when spining it makes very loud noise (like aeroplane when starts) , when i took off the cover on the bottom of the back i ve noticed some black powder, think its from the belt , when im trying to spin the drum by hand it doesnt go smooth , im not sure i have feeling that its a drum bearing because i think thats where the sound comes from,if im right, do you think i could change it myself ?and how? please help. thank you .
  • Kenmore Master
  • 3,463 Answers
Hi.
It definately sounds like the drum bearings have failed.
It is a DIY job, but not easy, as it entails stripping the m/c down,
If it is under 5 years old, then it should be covered by a 5year warranty., you will just have to pay for the labour, certainly the cheapest option.
Posted on Nov 23, 2008
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Hotpoint Washing Machines
Hi, do you supply spares as i need a new mod board for a hotpoint aquarius wf000g.. thank you.
You will have to go direct to Hotpoint, or a spares supplier to obtain a new board for your washer.
Oct 27, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Can a control module from an aquarius wf000g be swapped with one from an identical wf000g??
So long as they have the identical figures on the module, and the models of washers are the same then you can safely interchange modules
Mar 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi - reference our washing machine WF000G - the energy save light is flashing along with the on/off button and the machine wont run its cycle - can u help?
Do a search on Google using 'diagnostics, hotpoint, flashing lights'. There must be a manual which will identify what this fault is
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf000g washing machine won't complete a cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WATER IS POURING OUT THE DISPENSER DRAW OF MY WF000G
Normally if you take the soap slide draw out,you will see a hole underneath where the slide draw was. It normally blocks up with undesolved soap. Clear the channel then retry.Or sometimes water pressure is to high and then tends to splash internally causing water to drip out. Also make sure the slide draw is cleaned properly..
Sep 21, 2009 | Washing Machines
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
269 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
