Question about Honeywell Warm Mist HWM-2030 Humidifier
Honeywell Warm Mist HWM-2030 how to clean it ?
The metal part is all covered with hard residue form the water, how should i clean it ?
  • 23 Answers
Just uploaded the user manual to this site, which contains the cleaning instructions. You may also download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
Posted on Jan 20, 2011
Is not producing the mist
Most misting humidifiers use an atomizer to generate the mist. It is a small metal disk that vibrates very fast. I have yet to see one of these that ever lasts more than a year or two. If you remove the water container you should be able to see the atomizer. If you can put you finger on it and it isn't vibrating then thats the problem. On most small humidifiers it is cheaper to buy a new one that to try and get it fixed.
Dec 16, 2012 | Honeywell Warm Mist HWM-2030 Humidifier
Warm Mist HWM-2030 Humidifier: DOES NOT GIVE OFF VAPOR...
If the unit runs normally otherwise, but doesn't give off vapor, then your heating element is the culprit. i.e. if fan runs, switches in normal positions, indicating lights on, etc.and restart slide switch depressed and no mist, then, yes the heating element is the source of the problem. It may be bad, or otherwise it may just be scaled up from hard water, and require cleaning.
You may refer to your users manual, or if you no longer have a copy, you may download one at this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this answers your question.
kcomp1863
May 18, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
Start switch doesn't work
the switch is bad or there is a loose wire connection, if you have a multi-meter you can check the resistance on the switch, it should be 0.0-0.2 if the switch is good it could be the pump.If the pump is bad don't bother fixing it.
Feb 06, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
Have a warm air Honeywell humidifier. The "refill/restart" button is permanently on even if I refill the humidifier and the humidifier does not want to work now. How do I fix this? It seems a sensor is...
This may be due to one of two things.
1. If you turn the unit off or unplug it when you refill the resevoir, then plugging back in or turning it back on will not automatically reset the refill sensor. You must depress the restart slide switch on the bottom front controls to reset and restart the unit, or.....
2. It the refill light won't clear after refilling the resevoir or following the above step, the most likely cause of the problem is a scaled up heating element, which must then be cleaned.
I just uploaded a copy of the user manual to this site, but if you would like to download it directly, follow this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this helps!
kcomp1863
Dec 03, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
I don't know how or what to clean it with.
Just mosted the user manual to this site, which contains the cleaning instructions. Also, you can download the manual directly here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
May 18, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Water leak
there is no sealing replace the rubber band on the connection of the tank windman
Dec 30, 2005 | Honeywell Warm Mist HWM-255 Humidifier
Manual
I lost my manual as well but found this link to a pdf version in case anyone else has the same problem finding it as we did. http://www.appliancefactoryparts.com/content/pdfs/113129.pdf
Dec 18, 2005 | Honeywell Warm Mist HWM-255 Humidifier
Honeywell Warm Mist HWM-2030 Humidifier Logo
277 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
