Question about Canon ZR80 Mini DV Digital Camcorder
Will not accept any tape
When ever i open the load area, the camera makes two beep sounds, but it does open, when i load a tape in and compress the tape down, not closing the handle part, but the tape bay it self, it will open back up and make the same two beep sounds, also when i have the display open and the camera on, it says remove the cassette. i cant figure out what it could be, iv tried a whole pack of tapes, and i only use one brand of tape.. im very confused, do i have to have a memory battery in, because i do not have one right now.. thanks
  • 3 more comments
  • Anonymous Jan 05, 2008
    Same problem exactly for me.
  • yojan Jan 09, 2008
    I have the exact problem as described. Can't seem to figure this one out??
  • trayjj Mar 02, 2008
    the cam corder just eject the cam whenever I put one in.
  • Anonymous Mar 13, 2008
    I have the same problem.  Does anyone have an answer to this.  What does CANON say about this.  I am recharging the battery.  Is that part of the problem?  How do we get an answer from CANON?
  • Anonymous Aug 01, 2008
    same everyone says. spits it back out beeping and blinking "remove the tape"
I bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Posted on May 05, 2009
SOURCE:
Mini tape holder keeps opening and it displays error beeps... Has been used at beach on various occassions... Any help would be appreciated.. Is there anyway we could clean the inside mechanisms?
Sounds like a little sand and / or moisture made it's way into the camera. A call to the Sony Company Tech Support will let you know if one of the canned compressed air cleaners for computers would be advisable.
Another thought is to check if there is something in or near the hinge of the tape hatch apparatus. Sometimes I take one of those electronics foam "Q-Tips" and wipe out the area in case a piece of dust or fuzz or something is causing a malfunction.
May 14, 2011 | Sony Dvcam DSR-PD100 Camcorder
The camcorder will not accept a tape. without a tape, the thing will open and close. With a tape, it will beep and the motor spins, but it will not receive the tape.
hey pls put your cam with the 60 watt blub which can produce heat and put it like cabinet about 1 hours! it will solve it !
be happy for it!
Oct 28, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Switched on - battery OK - no function light, will not eject cassette but motor makes an intermittant noise
This sounds very much like a tape jam and the camera is trying to un-load the tape but it is stuck round the capstan, run the tape back a little if you can, that should release it from it's snag area okay.
May 24, 2010 | RCA CC285 Camcorder
Videocamera won't accept tapes
sounds like some tape is stuck in the mecanism...
Sep 24, 2009 | Canon ZR85 Mini DV Digital Camcorder
Sony video8 won't accept tape (door won't finish closing)
Sony DCR HC 42
I have the same problem as gskillman
Sony says it qualifies for a fla rate repair -- $201 plus taxes!!! Say what? This camera is only a couople of years old and has hardly ever been used.
Jan 11, 2009 | Video Cameras
Tape not loading
Chances are it is in need of a major cleaning. Usually by the time this happens the cleaning tape will do no good. A good internal cleaning is usually the only thing that will help it........Has it been droped? If it has then you could need repairs
Jan 03, 2009 | Video Cameras
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Cannot load tape
Problem resolved. I apparently did not have the "hatch" door open completely. I tried it again, heard a click and the mechanism lifted to accept the tape.
Nov 26, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Camera won't accept tape
tape senors is bad or have a bad tape
Jul 31, 2007 | Sony Handycam CCD-TRV308 Camcorder
Canon ZR80 Mini DV Digital Camcorder Logo
642 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
