Question about Ovens
GE JKP27WOP2WG double oven/top self-cleaning touch pad/bottom manual
Bottom manual working fine. Suddenly top will not come on, top OR
bottom burner. Gave no previous indication of a problem. Tried resetting
breaker, with no result. Please help if you can
  • 30 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
  • 10865 Answers
SOURCE: Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Posted on Aug 17, 2009
heatman101
  • 43501 Answers
SOURCE: GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 26, 2010
  • 5520 Answers
SOURCE: how to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Posted on Oct 29, 2010
I recently ran the self-clean option on my GE Profile JK955B0F5BB. Now when I set the touch pad to 350 degrees or more, the oven heats up to beyond 500.
That is not a valid model number, the issue is most likely the thermostat has failed. The part is about 12 dollars.
Jan 07, 2017 | GE Ovens
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Ovens Logo
474 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
