Turn on the cold water. warm to hot comes out for several minutes, not cold. also the hot water berley comes out.would like to get this problem solved' thank you
all of a sudden the cold water on my Moen single lever kitchen faucet is not working. I can only get warm to hot water from it. What's up with that?all of a sudden the cold water on my Moen single lever kitchen faucet is not working. I can only get warm to hot water from it. What's up with that?
I would check the strainers on the intake and the faucet spout. It is possible that sediment has built up and now is impacting thermostatic flow from the faucet... if one side is clogged its hard for the faucet to balance... try the stainer on the spout and any other strainers that may be on the supply hoses, valves, intake, etc...
good idea to let the cold water to run a bit to stop freezing up . Pity that you didn't do the same with the hot water. There is only hot water in the tank but the water in the hot water pipes will freeze as the heat goes out of the pipes. (Always to have to wait for the hot water to come through when you use the shower or bath.) The water will freeze up right back to the hot water tank
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
it has alot to do with the kind of saop you are useing,,,and lots of time the water is not hot enough to do the job right,,so i would run my hot water in the kitchen sink to make sure the water is hot first. if it is hot in the sink then it will be hot in the dish washer,,,but if it is cold then the dish washers water is cold to,,best to warm water then see what happens from there,,,remember the type of soap you are using to
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Just to clarify, you have it listed as your kitchen sink but the subject is under a listing for a bathroom shower body.
