Contact Service Hi, I need code to open contact service by remote. I wanna to adjust H hold n V hold. My tv used IC OM8377/N3/2 n EEPROM 24C16A. TV AKARI MODEL 21GA09Z
  • 89 Answers
SOURCE: 3310 contact service
it's a network problem your phone is fine
Posted on Oct 26, 2007
  • 14 Answers
SOURCE: I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Posted on Apr 01, 2009
SOURCE: Need codes!!!
1. Go to http://www.urc.philips.com/ 2. choose US URC modles 3. choose US2 4. choose US2-P63S. Really dumb but the owners manual states PH601S but in Philips web site its called US2-P63S -
Posted on Jun 12, 2009
SOURCE: code for astar tv
ASTAR LCD TV remote code for directv: 11531, 11548, 11738
The 11738 worked for me!
Posted on Nov 14, 2009
stormlover
  • 4 Answers
SOURCE: Remote Contol Codes for Lloyds brand Television
lloyd's lcd1932wb - i need info for setting up my universal remote. i dont know which category (tv, cable, vcr or aux) do choose for setting this flat screen and i cant seem to find the code doing a manual search? does anybody know if theres a 4-digit code to program my universal remote? i hav try'd manually searching but i just cant figure this one out?... its frusterating... could someone please help me? thanx
Posted on Nov 29, 2009
My hisense tv is saying eeprom error
Main system control memory IC [EEPROM] fault. Contact any service technician.
Electro help
Aug 18, 2014 | Televison & Video
Is there anyway to hard reset a Model 27v412t?
There is no way to hard reset this chassis TV. All of the settings are stored in an EEPROM chip that is programmed at the factory. There is a service menu to change these values but only some can be changed. The only options that can be changed on this model are CRT screen voltages and yolk alignments.
The only real way to completely reset the this TV is to replace the EEPROM with a new one, it would then have to be realigned and calibrated using the service menu with at least a Volt Meter.
This model chassis is plagued by many problems, usually with IC 301 which is your screen vertical control, it can cause lots of problems. The most common problem is a random shutdown of the set. Sometimes the board just needs to be soldered in that area.
If it's a parental code that needs to be cleared, this can be accomplished by pressing the Volume + button on the remote and the Channel + button on the front of the TV set. This will display the parental code. You will need the Original Remote to do any programming of this TV.
Jul 18, 2011 | RCA Televison & Video
29agm2 how to access the servise menu
Hello
Check these proceedings and find out which porocess works with your Sharp TV.
* Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
Mar 22, 2011 | Sharp 29AGM2 29" TV
What is my sharp code
Hello
To get into the service menu do the following.
Unplug the TV
LCD TVs :
After entering to the service manu, goto V-Chip options and Unlock it. You have to reset all V-Chip options after resetting it. OK.
Dec 19, 2010 | Sharp 32C-240 32" TV
My TV model 21QF2-A is locked please send me unlock code. thankyou
my sharp tv model 21qf2-A asks for a code or password of 4 numbers that I forget. What should I do?
Nov 24, 2010 | Sharp 32C-240 32" TV
Service mode
Hello
Here is the service mode entering process for Sharp Tv.
Unplug the TV
Ok.
Nov 18, 2010 | Sharp 25R-S100 25" TV
To get service menu on tv screen what code should i type by using the remote control ? ( Philips 20'' varadhan, zappa )
make tv off using stand by on remote and again power on it by remotr s.mode will disappear need to replace eeprom ic with original is provided by philips only
Aug 06, 2009 | Philips Televison & Video
Service code on remote to adjust the vertical height in BPL studioline 25 pip
if you cannot get a code go and fine up same tv remove the memory ic and use ic copier to duplicate the ic from good tv
Jun 06, 2009 | Televison & Video
Abnormal colour in aiwa tv ic noTA8759BN
You need to use Aiwa Service Remote to enter in service mode and adjust service data for red and Blue drive of CRT.
Do you have that remote and service data reference book of Aiwa tv ?
Oct 07, 2008 | Aiwa TV-S2011 20"
Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
