Question about D-Link AirPlus DI-524 Wireless Router
Secure dlink di 524 with wireless connection.
Unfortunately I have no cable close to the room that I have my pc in. I am using a dlink d 524 router connected to the modem in the other room on default settings not connected to a PC. Now all my naibers are using my internet for free. I have tride using ip http://192.168.0.1. and use username admin and password left blank. It just keeps asking for the username/password over and over. Is this because I am not conected with a wire and if so any way around it???
Thanks
Keefe
Do not live it blank , TYPE the word BLANK
Posted on Mar 10, 2009
  • 340 Answers
One of your neighbors may have changed it for you, but you have the hardware, just reset it, and get a LONG cable to it, as you only get problems trying to set the Router with the wireless connection.
After resetting to factory default,
Change admin password
Set wireless security:
Wikreless/Wireless MAC filter.
- here you allow witch MAC address is allowed to access your network.
you find your own MAC address by typing ipconfig /all in a cmd.
/Teis
Dont forget to vote if this is helpful
Posted on Nov 23, 2008
How do I change my DL-524 from unsecure to secure connection?
Enable WAP/WEP encryption, in the routers setup. Check your manual or DL the one below. ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Mar 07, 2010 | D-Link AirPlus DI-524 Wireless Router
Problem with Lenovo IdeaPadS10e and D-Link DI-524
This problem is with the firmware of your router so the best thing to do to correct this is to update the firmware of the router and you can get it from Dlink web site...
Apr 23, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink not working on my computer that receives signal
visible & unavailable means that the wireless security settings are not the same on the recently formatted computer, as on the rest of the network.
Open the wireless configuration for any computer that can connect to the network and copy the security settings (wep or higher) to the unconnecting pc
OR
connect to the router by cable from the non-connecting pc, use the web interface at http://192.168.0.1 to read the security settings, and copy the settings to the unconnecting pc
then it will connect
Jun 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Configuration as "Client"
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
AT & T Hook up to D-Link
If those lights are lit, they often have a "Code" this code is in the manual. Please find below a link for the manual I am sure all will be found in it. ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf Oh & I am sure ya can connect another WiFi'ed PC no prob's.
Sep 15, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
537 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
