Question about Microsoft Xbox 360 Console
Msg on xbox says ''not connected''
Just purchased wireless connection to X-box. It now shows that there's a USB port in the x-box but says it's not connected. What are we doing wrong?
  • dand2berry Nov 24, 2008
    both are plugged in. If it's plugged into the back there's a steady red signal, if it's plugged in the front we get the same thing. We're thinking, because we have a 2 story house with the computer upstairs and the Xbox downstairs the signal may not be a good one. Best Buy says the unit we have is guaranteed to get a signal. I think they're wrong! Any ideas?
  • Eeeeeeeeeekz May 11, 2010
    do you only have in the wireless connector and no ethernet cord? also where is it plugged in, the back usb slot aboce the ethernet cord?
    Problem Solver:
  • 3 Answers
Do you have a harddrive because if you don,t have a hard drive you can,t have live.
Posted on Jan 24, 2009
    Scholar:
  • 120 Answers
Sure, the usb port must be the back port, when you plug it in the light on the wireless adapter should be red. Once you turn the xbox on, the wireless should turn green. Go to test xbox live->test xbox live->edit settings-> the wireless settings should be at the bottom (the 3rd one down) click on it, (here if you have a password for your network insert the password. -> (press b to back out once) and test xbox live again. It should work if it doesn't please let me know, i'm doing the settings off the top of my head.
Hope it works.
Posted on Nov 24, 2008
My recently purchased LG 32LD550 TV is wireless ready. I purchased a LG AN-WF100 USB adapater but the wireless control input on the TV is of a different configuration. It seems to be a smaller connection...
The wireless control input on the back of the TV is not is not for a wireless adapter. It is used to connect a wireless media box, which you don't have. I have the same TV and use the wireless adapter. You want to plug your LG AN-WF100 into one of the USB ports on the left side of the TV.
Dec 23, 2010 | LG AN-WF100 (719192578838) Pre-802.11n...
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Connection to laptop
Most printers are connected to laptops via the USB ports. If the printer is supposed to be wireless, then you may have to connect the laptop via the USB port so you can activate the wireless port.
Don
Nov 23, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Wireless key
The user's manual does not show a wireless or wireless switch on this model;
http://www.scribd.com/doc/6995597/Copmpaq-Evo-N610c-User-Manual
You can purchase here:
http://www.nextag.com/wireless-pcmcia-adapter/compare-html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Connecting my xbox to internet with utstarcom um100c modem on pc
You are not going to like the answer I have for you. Forget connecting wireless with X-box. Purchase a router with an Ethernet port. I do this for a living and run in to this problem all the time. Trust me, hard wire with X-box is the way to go. A Lynksys router is a good router and is also VERY user friendly.
Dec 31, 2008 | Computers & Internet
How do you install wireless usb adaptor
A wireless USB adapter is a simple device that connects to an open USB port on your computer or laptop, allowing you to connect wirelessly to a network that is within range. They come with different connection speeds, ranges and security protection allowing you to connect to the Internet and use email servers, without complicated setups. Installing USB adapters to a computer is a simple task that anyone can perform. With just a few steps, you can access wireless networkmag-glass_10x10.gif where there is one.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions
  1. Step 1 Research around before purchasing a wireless USB adapter. There are many different networking companies such as Belkin, Netgear and Linksys (see links in Resources). Compare prices and features such as speed in megabytes per second (mbps). Look for wireless USB adapters with a compliance of IEEE 802.11b or IEEE 802.11g. These options give you increased security on your network.
  2. Step 2 Plug your purchased USB into a USB port on your computer. Depending on the chosen model, you may have an installation CD. Place your installation CD into the CD-ROM on your computer, and follow the setup instructions to install the wireless USB drivers. Some adapters will install automatically.
  3. Step 3 Locate the wireless icon on the lower right of your computer screen. If there is an "X" marked on it, use the manual that comes with your purchased wireless USB adapter to configure it properly. The wireless icon usually lights up when a wireless connection point is detected.
  4. http://www.microsoft.com/windowsxp/using/networking/setup/wirelessadapter.mspx#2
Dec 11, 2008 | Computers & Internet
Usb Trouble
The USB ports all share a single power source. It may be that the Ipod being added overloads the connections.
You might want to consider purchasing a USB hub, but make sure you get one with a Power Adapter to boost the current to your devices.
Oct 01, 2008 | Microsoft Wireless Laser Desktop 4000...
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Microsoft Xbox 360 Console Logo
218 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
