Question about Vizio L32 32 in. LCD HDTV
Vizio 42'' TV Sounds like it is in a metal tube.
I have plenty of volume, but the sound quality is terrible. It sounds like it is in a metal tube. Not much bass either. Anyone have an idea?
The volume was up on the TV, but down on the cable box remote. By raising both volumes the sound quality improved dramatically.
Posted on Nov 24, 2008
On the Vizio D TV's......the quality of the sound is horrible. It sounds equivalent to a 1970's 12 TV!! Did we miss something when setting it up?
Hello, Kim -
I found the following evaluation of the sound quality for the Vizio D television from the web site:
The sound quality is sub-par, and the TV doesn't get very loud. You will definitely benefit from having a separate sound system. Even a cheap sound bar would be an improvement.
[End quote]
So, you probably didn't make any errors in setting the TV up and may need to purchase a sound bar or speakers. We have an older model Vizio TV and found the sound quality is improved with added speakers. Our speakers can work as a sound bar or 2 speaker units on each side of the TV.
Dec 28, 2017 | Vizio Televison & Video
Volume goes up, picture freezes, tv reboots
Sounds like a surge to me. Why not give Vizo call to see if anyone else is reporting the same problems. It's a fantastic tv.
Apr 22, 2014 | Vizio E421VA 42 in. LCD TV
My 42 inch lcd vizio tv flashes like a stobe lite after a minute of powering it on then goes black what can i do
That sounds like an inverter problem. Check the capacitors on the inverter boards. There will be two on each board. The master inverter will be on the far left side, and the slave will be on the far right side. You will have to remove the metal covers over the inverter boards. Should be 4 small phillips head screws. If the capacitors have bulging tops, replace them.
Jan 15, 2013 | Vizio VX42L 42 in. LCD TV
Volume will not stay the same on commercials or loud sounds like a gun shot tru volume is on
In the UK, there is talk of insisting the TV companies reduce the advert volume to the same level as programmes. There is a lift at present as it increases peoples awareness.
Mar 09, 2011 | Vizio GV42L 42 in. LCD Television
Volume stays low
sounds like the unit has had sound restriction acctivated its a tool desinged for when they are installed in motels so as not to upset the nabours look up the sound menu and scroll to restrict sound and see what it says other wise in the main menu there is a factory reset. use that to reset all the units settings
Apr 21, 2010 | Vizio VX42L 42 in. LCD TV
Sound quality is terrible on my Crosley CR79 turntable. Sounds very tinny and terrible. Got a new needle and the problem still exists.
This could be an earth lead to the cartridge problem, or the cartridge itself. Check the connections.
Feb 07, 2010 | Crosley 0187SST Turntable
42 in Vizio TV volume stopped working
you can eithor get the board from or hook up surround sound system-and not use tv speakers
Sep 11, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L42 - sound set to 0 and still loud distorted sound
I unplugged the TV and let it sit for about an hour and now appears to be working as before. Still strange, have never experience this before. I could understand no volume.
Sep 03, 2009 | Vizio L42HDTV 42 in. LCD Television
Vizio 42 lcd connected to cable sound is ok but
is the cable in all of the way? sounds like something is interrupting the transmission. i know the tv is large but try using it somewhere else. this will distinguish weather the problem is the tv or the cable
Jul 23, 2009 | Vizio VO42L 42 in. LCD TV
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Vizio L32 32 in. LCD HDTV Logo
174 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
