Question about Whirlpool MH1150XMQ Microwave Oven
Microwave won't come on after circuit tripped
I was trying to replace the two lightbulbs under the microwave. One of the light bulbs broke off in the socket. I replaced the other one, and then pressed the button on the microwave to turn on the lights to see if the one I replaced worked. When I did that, sparks blew out of the socket where the broken piece of light bulb was, and it tripped the circuit in my kitchen, plunging everything into darkness. I went to my fuse box, found the tripped breaker, and everything came back on, except the microwave. Is there a fuse or a breaker inside the microwave that I may have inadvertently blown up that I can replace myself, or have I destroyed my microwave. It seems strange that a light bulb can do such damage, but you never know.
  • Anonymous Dec 15, 2008
    how do change the fuse
  • Whirlpool Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations.
But you'll almost certainly need to have the control board repaired.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 24, 2008
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
Magic Chef microwave MCO160UW stopped working after trying to change the lightbulb.
First thing to do is unplug it and take a pair of needle nose pliers and get the base of the old bulb out and replace it. Microwave ovens have a lot of things wired in 'series' which means that is one switch,bulb or any thing else in the circuit goes out then the circuit cannot complete it's path and will not let the other parts function. It is a safety feature that is built into them. As in many things I think they over do the safety features but they didn't ask me when they built it. LOL! Try replacing the bulb and let me know how it works.
Mar 15, 2014 | Microwave Ovens
Lights under microwave will not come on
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Oct 14, 2017 | Frigidaire FMT148GP Microwave Oven
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Light under microwave
i need the model number pls in order to help you
Nov 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
Spacemaker XL Microwave Oven MODEL JVM1640 Help
please check control circuitand related circuit and wiring mains fuse and related circuit
Oct 04, 2007 | GE JVM1640 Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
381 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
