The speaker are not working properly I getting audio sound from only the front channel.
  • babaed52 Nov 23, 2008
    I have an LG DVD home entertainment the speaker channels on the receiver are not working properly. The rear and the center are not working only the front and the woofer. I want to know if this problem can be less expensive to fixed. The model No. LH-T550TB.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Most problems similar to this could indicate that:
  • the speaker selector is set to only the front; or
  • the surround processor is faulty and only processes the front; or
  • the audio amplifier of the other channels are fault;
  • the speakers of the other channels are fault;
  • the setup/settings/configurations needs to be redone;
  • a reset is required;
  • firmware glitch.
It would help to narrow down if you could postback the brand and model and other information related and prior to the issue.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 23, 2008
  • Louie  Role
    Louie Role Nov 23, 2008
    Based on the model, I doubt if anything is wrong with the unit. It would seem however that this model will require a digital/optical output or a 5.1 analog output from your source. There will be no true surround sound from analog left/right only sources. To verify, pls try a DVD player as a source.
    If this has been like this since new, then the above supposition would hold true, if however the opposite is true, it used to work but not anymore, then it could only indicate a hardware fault which of course would require repairs.
    Scholar:
  • 112 Answers
We need a whole lot more information than that. Tell us everything. What you are trying to do, what equipment are you using to do it with, what make an model is it, what have you tried, etc. thanks.
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
My 5.1 channel speakers are not working
WHTS YR SPEAKER MODEL LOOK FOR THE INPUTS U R PROVIDING THE SPEAKER SYSTEM IT MUST HAV TWO FRNT TWO REAR ONE FR SUBWPPFER AND ONE FR CENTER CHEK YR SOUND CARD SETTNGS FIRST U R ONLY USIN STEREO OUTPUTS EO
Jun 06, 2010 | Microsoft Windows 7 Ultimate for PC
Sound is very low,it's a new computer&speakers. The speakers are Integrated 5.1 Channel Audio and Dell Speakers.
check properly that the system sound is properly configured and check that the all the speakers are working or not then see that the setting is 5.1 audio channel then also check the volume controller level in the amplifier. if all these settings doesnt work then download srs soundbox from www.google.com and install it and configure it properly to get a loud sound.
Sep 04, 2009 | Dell Audio Players & Recorders
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
Feb 14, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No Windows Media Player Audio from Surround channels
On WMP - go to Tools > Options > Devices > Select Speakers > click Properties > Audio Device to Use - ensure you select your audio Card (Not direct sound - just a precaution) > Advanced > Volume Tab > Speaker settings click on Advanced > Select the type of Speakers you have. - Hope this helps, let me know!
Oct 28, 2008 | Creative Labs Audigy 4 Sound Card
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
14 people viewed this question
 Grubhead
Grubhead
