Question about Sony KP-51WS500 51" Rear Projection Television
Three separate images about 4-5 inch apart on my TV
I turned my KP-51WS500 on and all of sudden I see three separate image. Seems the picture is out of sync with green shadow being more prominent. Could it be the problem with CRT tubes again. 2 years ago, I had to replace Red and Green CRT tubes but then the symptoms were quite different; the colors will start normally but would gradually turn green and after about 45 secs it would turn off. This time, I see three saparate images about 4-5 inch apart.
Would could be the problem this time? and how much would it cost me to repair. Can someone guide me
  • 4 more comments
  • bmurphy2626 Dec 16, 2008
    How do you remove the IC from the board?
  • dugg21042 Jan 04, 2009
    How did you finally resolve this issue?
    What does IC stand for and how costly was it to fix?
  • Anonymous Jan 08, 2009
    hi, i have the identical problem on my sony tv. i was wondering if u fix your problem and what was the fix. i am going to start looking for those 2 ic's and blown pico fuses located on the "D" and "G" boards this weekend. i would like to know if there are any large storage voltage around this boards that i need to be aware....please respond if u can help at
    thanks, david.
  • shue320 Jan 15, 2009
    it seems to be a recent common problem...i read some reviews off and someone had said that to replace all 3 tubes, it would cost $1000! that's a bit much. we have a sears tech scheduled to come out in 2 weeks but i dont know if it's worth spending that much money to fix. anyone resolve the matter?
  • davidrose9 Feb 08, 2009
    I have this same problem Sony wide screen projection TV KP-51WS500
    I turned the television on this morning and it was blue green red starts from the center goes to left from center and right from center three colors or images trails even. I hope someone can share some solutions like cost of repair I don't think I'd attempt repairing myself unless it is'nt to complex..Thanks in advance for any and all imput on this.
    I turned my KP-51WS500 on and all of sudden I see three separate images starts in center goes to the right and then to the left from center, like color shadowed images. If any one had this similar trouble repaired please do tell, and if this is not too complicated to repair some impute or links sure would be much appreciated. Thanks
  • 10,594 Answers
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Posted on Nov 24, 2008
Have three different color images (red,blue,green)
It is symptom of convergence output ICs failure, replace convergence output ICs located on D board to fix this problem.
Call local tv repairman to replace defective ICs if you do not have prior experience of electronics stuff repair.
Dec 15, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony rear projection tv kp-51ws500 no picture. Standby light blinking red 5 times. TV has sound but no picture. Before the picture went out TV was turning green then red and had curved lines going...
Blinking 5 times is a sign of at least one of the three video tubes overcurrenting, which will eventually shut off the image. It happened with me but with my red tube over-illuminating. The solution is to reduce the drive intensity on the offending tube. Remove the front speaker grill. Behind it you will find a panal with 6 pots, these are drive (brightness) and focus for each of the 3 colors. My fix was to turn down the red intensity to zero and (after a restart) bring it up slightly till the image was acceptable, colorwise. I did have to adjust all 3 intensities to get a decient color balance along with the focus's on all three tubes (the drive intensity adjustments will knock the focus out as you go). I used the auto-adjust patterns to focus on, and you may want to use a stationary image, such as a paused DVD scene or a video game, to focus on. I still haven't found a way to clear the error code, but I learned to ignore it. The result isn't perfect, but it's very acceptable and it'll do for awhile (and it didn't cost anything!). Good Luck.
Dec 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Convergence problems w the color tubes
Press the Majic Focus button on the front. If that doesn't fix it then the convergence ICs may be bad.
Mar 31, 2010 | Sony KP-51WS500 51" Rear Projection...
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
The colors are separated. Images are blurry and
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Oct 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Picture is weak, has gosth image and is warped.
you are having problem in your IF CIRCUIT it needs to be align take it to a tech to replace the IF ic Or transistor
Mar 26, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
