Question about Philips Televison & Video
Hi, I have a Philips HD model # 55PP935217 Projection TV. The problem is that only the red and green show up on the screen. When you remove the front screen the blue is light up but tou can barely see the pricture coming thru it. When you remove the top lens and set it off to the side, the blue part that it bolts to is not clear it has a deep burnt yellow look to it. Is it possible the part # P16LTG00BMB(U)is bad? The other two colors are clear.
    Top Expert:
  • Philips Master
  • 81,285 Answers
One of the CRT's is defective, very expensive to fix if you can still get parts.
Posted on Jun 22, 2017
  • 308 Answers
SOURCE: green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Posted on Jan 14, 2007
premtech
  • 934 Answers
SOURCE: Philips 51in. Rear projection DPTV345
That is quite an undertaking to replace all three crts in a conventional PTV - I've been in electronics more than 20 years and I've never done that... One because it's far too expensive, two because it's unusual that all three crts would be bad and if they were I'd REALLY suspect problems somewhere else and three because of how labor intensive it would be to remove, install and align three new cans.
That said, you should be able to get them through Vance Baldwin or Tritronics Inc.
Bill
Posted on Mar 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: 55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Posted on Mar 28, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 9p6040 c102 philips magnavox rear projection tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 16, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Sony KP-51WS500 Rear Projection TV colors are distorted.
  • Screen looks 3D
Posted on Mar 13, 2009
My 52in hd tv wont show a picture and when you cut it on it just light up red but no picture and i cant get to adjust the convergence on the menu.
If the screen is a bright red its indicating an issue with the CRTs could be the red has shorted or the coolant in the blue and green is needing replacement which makes the red Dominate. Looking into the blue and green lenses will verify if its a coolant isssue or not. The convergence issue is most likley failed convergence ICs and the associated 6.8 ohm resistors need replacment.
Aug 20, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture looks like its red and green 3-d,Phillips 55pp935217
Ur convergence it dead,Need a convergence kit,use what in that kit,Know how to solder righht?Tries Tv Repair World.com,Ebay.com.
Oct 06, 2009 | Philips 55PP9363 55" Rear Projection...
I have a Philips projection TV with a screen protective cover, how do I remove the cover?Its a model 55PP935217 HDTV. Nobody I have found can tell me how to remove this cover.
Why do you want to remove this protective cover. First of all any attempt to remove this will create more problems than you can shake a stick at. You will not successfully pull this out and reinstall without. Trust me...some things are better left alone...you have been warned!!!!!!
Oct 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
I need help finding the correct HD cable for my TV.
yOU WILL HAVE TO HOOK IT UP ON THE COMPONENT INPUT THE VIDEO PART IS GREEN RED AND BLUE WITH AUDIO RED AND WHITE. OR IF YOU HAVE AN HDMI INPUT ON YOUR SET YOU CAN HOOK IT UP THERE.
Sep 14, 2009 | Televison & Video
Phillips hd tv
convergence i.c.s change both of them even if only one color is out. if one is bad the other is usually going to give out soon. the part # should be. stk 392-120. also check resistors around i.c.s if the open you wont be able to adjust convergence.
Mar 20, 2009 | Philips 55PP9352 55" Projection Television
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Philips 55" hdtv rear projection internal parts
If your model number is 55PP935217 you dont have a ballast. You have a rear projection with 3 CRts . Please let me know if thats the correct model number and what your symptons are. I will be able to help you get what ever part youre needing.
May 22, 2008 | Philips 55PP9352 55" Projection Television
Green dot in middile of my screen
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
