Question about Acer Aspire 5315 Notebook
DISCONNECT WITH INTERNET
I AM NOT ABLE TO ACESS THE INTERNET.THIS PROBLEM OCCURED BECAUSE THE NETWORK DIDNOT ASSIGN A NETWORK ADDRESS TO THE COMPTER. WHAT I HAVE TO DO.
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    Computer?
    OS?
    Router model?
    What have you done so far?
    /Teis
Try resetting your router if you have access. Do this by hitting the reset button or unplugging the power and plugging it in again.
If that didn't work, restart your computer.
Posted on Nov 23, 2008
HOW TO PUT MY IP.ADDRESS IN
Open the Start Menu, right-click on Network, and select Properties. The Network and Sharing Center opens...click on Manage network connections. Right-click on the network adapter you want to assign an IP address and click Properties. Highlight Internet Protocol Version 4 (TCP/IPv4) then click the Properties button.10 Nov 2013
How to Assign a Static IP Address in Windows 7, 8, 10, XP, or Vista
www.howtogeek.com/howto/.../how-to-assign-a-static-ip-address-in-xp-vista-or-window... HOW TO PUT MY IP ADDRESS IN Google Search
Dec 09, 2016 | Computers & Internet
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Canon IR 2520 lost IP address
This is regular feature. Nothing defective here.
IP address is to communicate with the router on wire or wireless.
Dynamic IP address will assigned to your printer again when re-connected and will be lost when disconnected.
Static IP address assigned will be reserved at the router for the device even when the device is disconnected.
Apr 18, 2016 | Canon Office Equipment & Supplies
How do i get vodafone gprs settings on htc p3400i
Go to Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection:
ex. Vodafone
Select a modem:
Cellular Line(GPRS)
click next
Acess point name:
portalnmms
User name:
Password:
Domain:*
Go to Advanced->TCP/IP
select radio button "Use server-assigned IP address"
Go to Advanced->Servers
select radio buttion "Use server-assigned address"
Step 2
Start->Settings->Connections->Tasks->add proxy setting
Select "This network connects to the Internet"
Select "This network uses a proxy server to connect to the Internet"
Click "Advanced" button
Tap on HTTP
Server: 10.10.1.100 Port:9401
Username:
Password:
Domain:
Tap on WAP
Username:
Password:
Domain:
Step3:
Start->Settings->Connections->Advanced
In "Select which networks are automatically used"-> click the Select Networks
Programs that automatically connect to the Internet should connect using:
Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using:
Reboot the mobile for the changes to take effect.
Mar 16, 2011 | HTC Touch P3450 Smartphone
How to restrict adsl internet acess ?
please check the all pc mac address & this all mac adress u can do allow & deny in your adsl modem
Jul 05, 2010 | Computers & Internet
Cannot connect to open wireless network Invalid IP Address
Either the network requires you to manually configure your ip settings(unusual but not unheard of) or your wireless adapter is not set to get settings from DHCP. Check to verify that your wireless adapter is set for DHCP and if this is correct then you'll need to contact the administrator for the wireless AP and haver them check their settings.
Jan 08, 2010 | Dell Latitude D610 Notebook
No internet or ip adrdress
Check you have Network Adapter in your Network Connection Setting.if it is there then all you need to do is to set IP address,Subnet mask,dafault Gateway,Preferred DNS Address and Alternate Address.
But if it is missing then you need to reinstalll your Network Adapter Driver.The problem might have occur as you restore your system to a point when Network driver was not install.
Anyway, you don't have the driver, download it from the link below
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=INSPIRON1545
Just Select your Operating System and download the Network Controller Driver and Install.
And assigned your IP address,Subnet mask,dafault Gateway,Preferred DNS Address and Alternate Address so that you can connect to internet.
Jan 04, 2010 | Dell Inspiron 1545 Notebook
I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Dec 08, 2007 | Computers & Internet
Wireless connection fails: won't assign address
As ever starting with the simplest of solutions normally works, well spotted.
Nov 28, 2006 | NetGear WGR614 Router
Acer Aspire 5315 Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
