Question about Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher stuck in drain cycle
E4 flashes on the screen only drains
    Sergeant:
    Champion:
  • 338 Answers
Whats the model number?
Posted on Nov 25, 2008
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
E4 flashing and water not draining away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 12, 2011 | Smeg 24 in. DWF614SS Stainless Steel...
What men cod e4 on dishwosher kenwood kdw12st3a
Hi
Error e4 on Kenmore usually occurs when there is drain clogging or due to debris stuck in the bottom of the dishwasher. Drain out the excess water from the dishwasher, now remove the mesh and the filter. Now, check and remove any food material or debris stuck. Now pour 1-2 litres of luke warm water and let this water drain. After this replace the parts and run the dishwasher on eco mode without any tablets or soap. Try this 2-3 times and then reset the dishwasher by unplugging it for 5-10 minutes.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Kenmore 15762 Dishwasher
New World Integrated Dishwasher DW60 E4 flashing and beeping. Managed to get it going for a while with a d/w cleaner, it filled, water heated but then E4 error kept flashing and it stopped, had to...
Sounds like the drain pump has jammed - probably a bit of broken glass or a fruit pip, etc. isolate electricity supply, lie the machine on its back, after removing as much water as possible with a sponge etc, remove the base plate if fitted and the small drain pump should be removable, either secured with screws or just a simple 'twist' bayonet cap fixing. Check for blockages / foreign bodies in pump.
If not pump, ie you can hear it running on drain cycle, check drain hoses and plumbing for blockages. Remember there are usually two pumps, the bigger one is the wash pump. Some machines use 1 pump only, and reverse the direction of rotation for wash / drain. A foreign body in these pumps often rips all the rotor vanes of and you will need a new pump.
Feb 02, 2018 | Dishwashers
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Error 4 displayed on a danby ddw1806bsl dishwasher
E4 is overfilled condition.
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
May 10, 2008 | Danby DDW1806BSL Stainless Steel Built-in...
Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Mar 09, 2008 | Dishwashers
Kenmore 24 in. 15932 Built-in Dishwasher Logo
54 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
