Question about Ryobi Cultivator
Ryobi ry60514 tines won't turn
Cultivator tines do not turn whengas is applied. Thanks in advance for any help.
  • unkle jed Apr 10, 2009
    When I apply gas the tines as well as the shaft the tines are attached to wont turn.
  • 50 Answers
There are shear bolts that hold the tines on. they are designed to snap when u hit something big such as a big rock or pipe or something like that. they are designed to snap at so much pounds of pressure so u dont break any gears or gearshafts. a lot of times people dont realize this and put regular screws or bolts in it and run it. when they hit something they ussually snap the gearshaft inside the tiller. i have replaced this on my fathers tiller cause he did the same thing. so either u might need to put new shear bolts in or if u had a regular bolt in u probably snapped a gear shaft or a gear.
Posted on Dec 04, 2008
Oil to gas ratio of ry60514 ryobi roto tiller?
50 to 1
Apr 02, 2015 | Ryobi Garden
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Ryobi ry60514 is frozen.
Does the engine turn over? If not then it has most likely seized. If the engine turns but the blades won't then make sure you didn't wrap something around the tines causing it to bind up
Jan 17, 2013 | Ryobi Cultivator
I can start my RY60514 cultivator but it won't stay idol for very long and dies every time I engage the throtle.
take the muffler off the engine and try it if ok open the muffler and clean it the screen inside gets plugged with carbon
Apr 30, 2012 | Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Ran fine now it seems like the engine is seized , only two years old the gas and oil mixture was fine it is a ryobi 60511b
take out plug and try to turn tines by hand and check the tines for free movement if free try to pull start it if still seized spray cylinder with penetrating oil and let sit if still wont turn over possible internal breakage-crank/piston rod
Mar 14, 2010 | Ryobi Cultivator
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Tines do not rotate with any power
what kind of cultivator??? sounds like oil on the cutch or broken clutch need more info.
Jul 13, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Ryobi (new) will not till forward. Model RY60502
mine did that until i raised the drag stake to barely touch the dirt and sometimes i have to raise the tines out of dirt and dig back in hope this helps
Jun 09, 2009 | Ryobi Cultivator
Ryobi Cultivator Logo
839 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
