My Washer Control Locked light went on and now it's blinking and won't work. I tried the end of cycle button(hold for 3 sec), I tried hard boot(control on, drain/spin setting, press no spin and rinse hold four times). Is there any other ideas?
SOURCE: Whirlpool Duet HT Washer
I guess electric door lock just stacked. To prevent door breakage call to your local appliance repair company.
_______________________________________
http://www.allstarsappliance.com
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: duet washer has f6 diagnostic code
The following link explains how to troubleshoot the "F06" error code:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The first step in toubleshooting this problem is to check all the connector plugs between the Drive Motor, MCU and CCU. Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
If the tachometer is determined to be the cause of the problem, it is part of the MCU. The MCU is not serviceable and will require replacement. Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. For more in depth troubleshooting tips refer to your technical data sheet that came with the washer. It is located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, dianostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
If you have questions, or require additional assistance, please let me know.
NOTE: For better access to the toe panel screws, you can prop the two front feet of the washer up. (A 2x4 works real well for this).
SOURCE: HELP! I have a whirlpool HE3 frontload washer and
you can manually open the door by first unplugging unit from power,then remove lower toe kick panel under door,reach up to find the door latch assembly and feel for a small tear-shaped plastic tab located on bottom of door latch and pull downwards 1/4" till you hear a click and door should open manually
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
