Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Freezer problem I have Amana Model SQD23VW 25.5 cu ft side by side. Fridge and freezerstops cooling but the fan and compressor still runs so I have to shutthe freezer and fridge controls off and wait for a while to turn themback on for it to start cooling again, and the longer you leave thecontrols off before turning them back on the longer it cools when youdo turn it back on again, and the water in the door does not workeither. The ice dispenser does not work either unless you leave itturned off then when you turn it back on it only makes 1 batch of icebefore stoping to.
  • thor669 Nov 25, 2008
    hi thank you for your help can you tell me where at in the back they are located or where i might find a drawing that way i know what i am looking for thanks again for your help
  • 33 Answers
Have you checked the Heater element for the defrost to see if it's good? It sounds like the coils inside your freezer are freezing over into a solid block of ice which in turn will cause it to stop cooling.....efficiently. When you leave the unit unplugged, it gives the unit a chance to thaw and it work properly until the coils freeze over again. If heater is not the problem then Defrost Thermostat probably is. Both located in back of Freezer.
Posted on Nov 25, 2008
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams or . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at anytime.
Apr 09, 2013 | Amana Refrigerators
Compressor line going to freezer is iced up. won't get lower than 25 degrees.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Sep 09, 2011 | Amana 22.6 cu. ft. Side-By-Side...
My fridge(& freezer) started giving off a bad burnt odor then stopped cooling (amana 25 cubic/mod #afd2535fes). any suggestions as to what it might be?
You said it stopped cooling, does the compressor kick on, or is it dead? Is the condenser fan operating (the one that blows across the condenser grill by the compressor)?
Is your condenser grill clean? What indications are you getting specifically?
Jul 15, 2011 | Amana 25" Cu Ft French Doors Bottom...
Amana 25 Cu. ft. French door Freezer Fridge quit
Feb 20, 2010 | Televison & Video
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer dying first, fridge failing...
Is the compressor running. also check to see if the fan next to compressor is running. They should both run at same the compressor fan running and compressor not? Could be the compressor start relay. Next, is there frost buildup on inside back wall of freezer? If so u may have a defrost control out or defrost heater or defrost terminating thermostat out. Greg
Jun 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridghefreezer not working
Make sur compressor is running.
Unplug for 20-25 min., plug it back in and listen for compressor to start. You will need to be behind the Ref so you can tell if you hear the compressor or the condenser fan running.
Ice/frost build up in freezer.
This is a failure of the defrost system. Evaporator fan, heater, timer, one or more could be bad.
Jan 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Fridge and freezer not cooling properly!
Sounds like a problem with defrost system , It could be one of there components , timer, heater, or defrost thermostat. try advancing the timer, down at the lower area behind the grill. with a screw driver by putting it into the dial advance and turn it till it clicks and the unit shuts off. now you should see red glow at bottom of back panel in freezer or here sizzling . if this does not happen then it will be the heater or the thermostat.
Apr 27, 2017 | Amana 22.6 cu. ft. Side-By-Side...
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
263 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
