Question about Kenmore 98702 Stacked Washer/Dryer
Siemens Ultrsense WFXD5201 Series Washer
How do I open the small access panel on lower right front panel.
It turns, but I dont want to pry it off after that.
There is a small hole there.
Is it a latch?
3 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: Washer door gets stuck and
You have to replace the door lock and switch assembly which is part number 131763202. Your machine is made by Frigidaire so check out the procedure here.
Replacing the Door Lock and Switch Assembly on a Frigidaire/Frigidaire-made Front-Load Washing Machine
Posted on Oct 10, 2010
rickead1
  • 1998 Answers
SOURCE: asko washer door won't close. Worked it manually
you would start at the top back by losening the screws that hold the upper cover on the machine and when you remove these screws you would then slide the panel to the rear of the machine. nest you will see the rubber gaskey along the door has a metal ring simply use a screw driver without ripping the rubber boot to remove the ring. After this then u can remove the screws which hold the front panel which also has the door on it the part you are describing sounds like the door hasp or the catch the holds the door closed. because it is an asko your probably better off going to manufacturer to order your parts because this is a foreign model. please remember to rank how this opinion has helped in your appliance situation and if i can answer anything further please message me back
Thanks again
Rick
Posted on Nov 28, 2010
Testimonial: "Great advice thanks, now to see if I can do it...!!"
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
The washer is locked and will not open.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 17, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Whirlpool washer door wont open
Jul 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you open pump door?
The access panel on the lower front of the washer can be opened by prying up the lower side of it (near the small hole, I'm guessing repair guys have a special tool to do it), and at the same time twist the whole thing clockwise.
Do the reverse to put it back on.
May 05, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch series 300 washer: E:04 error; how to remove pump cover
You can get that cover off, by prying it up at the bottom and spinning the thing clockwise. then there is a large hand turnable plug inside.
Once you turn it water will start leaking out, you'll have to get in and pull out the crud from the pump screen there to clear the jam. Good luck!
Apr 10, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Whirlpool washer door is locked on the Duet Series. Tried all the basics but still nothing.
Dec 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he3 washing machine door glass
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 14, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
