Question about InterAct Accessories InterAct PowerPad Pro (SV-234) Game Pad
Programming how do you program a powerpad pro controller for xbox
  • Anonymous Dec 17, 2007
    NEED TO RESET IT
Walmart controller not working on my pc
Set up a wired controller
Step 1: Install the Xbox 360 controller for Windows software
Use the installation CD that came with your Xbox 360 controller for Windows before you connect the controller for Windows to your computer:
  1. Insert the installation disc in the CD or DVD drive of your computer. If the Setup program does not automatically start, change to your CD or DVD drive and run the setup program.
  2. On the setup screen, click Install.
  3. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
If you don't have an installation disc for your Xbox 360 controller for Windows, you can download and install the software online:
  1. Go to the Software Downloads section of the Microsoft Hardware website.
  2. Select Gaming as the product type.
  3. Select Xbox 360 Controller for Windows as the product.
  4. Select the version of Microsoft Windows you are using on your computer, select your operating system language, and then click Download.
  5. Click Run.
  6. The Xbox 360 Accessories Setup program installs the necessary files to your computer.Note You might be prompted to restart your computer after the installation is complete.
Step 2: Connect the controller to your computer
After you install the software, plug your Xbox 360 wired controller's USB connector into a USB 2.0 port on your computer.
Step 3: Test the controller
To test your Xbox 360 wired controller on your computer, follow these steps:
  1. On your computer, click Start, type Run, type joy.cpl, and then press ENTER.
  2. Select Xbox 360 Controller, and then click Properties.
  3. Test your Xbox 360 wired controller by pressing a button, pulling a trigger, or moving a stick on the controller. If the controller is functioning correctly, you will see the corresponding action light up in the application. If the application does not recognize your controller, see Troubleshoot your Xbox 360 controller for Windows.
Jan 06, 2014 | Microsoft Xbox 360 Controller
How do i program it for my xbox
I got one about a week ago, and it works fine for most things... I had trouble with the programing button, since the clear button did nothing ..... to program the controller, you need to hit program button, then hit the buttons you want it to do, the first button you hit will be your start button. like if you wanted to do X Y R R L A, you would hit program and it should light up flashing... hit X Y R R L A and then hit program button again. when you want to use the series of buttons just hit X and it will automatically go through them. Now if you want it to go just normal X again you have to hit program button then X then hit program button again. that should just be the x button all over again.
For the Turbo Button you need to hit the button you want to repeat and then while holding that button down hit the Turbo button..... it will start flashing and boom you have rapid fire and you only have to hold button down to get it to repeat...
Aug 06, 2010 | Intec XBOX CONTROLLER- PRO MINI CONTROLLER...
Can i program a time schedule for x box to be accessed through th
Sounds like you are looking for the "Family Timer" feature of the Xbox 360.
go to My Xbox, open System Settings, and selectFamily Settings, Console Controls.
As shown here: http://www.xbox.com/en-US/support/familysettings/console/xbox360/consolefamilysettings.htm
May 14, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How to program/use a wireless xbox controller on another xbox
Press the sync button on the top side of the controler and the sync button on the front of the xbox. It should take less than 20 sec
Apr 18, 2010 | Microsoft Xbox 360 Wireless Controller
I just bought a second wireless controller for the 360 Xbox and it blinks continuously with new batteries
did u program it to your 360? if not there is a button on teh top of the controller and on the xbox. they both are a circle button with "radio waves" comming off of them. press both to program it. good luck
Nov 14, 2009 | Microsoft Xbox 360 Controller
My controller wont work
that's probably because it's a cheaper version of an Xbox controller there isn't really any way to program it you can only really be done with an Xbox 360 controller sorry...
Jun 06, 2009 | Intec XBOX CONTROLLER- PRO MINI CONTROLLER...
I want to play games from the older systems on my xbox 360, doing this by using emulators, and roms. i want to know how to do this, i have a mode chip, and this is the xboxs 360 pro 60gb. if you can help...
You don't need a mod chip, all you need is Windows Media Center. Just download an emulater, put it in this category (just for Windows XP) C:Documents and Settings\All Users\Start Menu\Programs\Accessories\Media Center\Media Center Programs\, download some ROMS, Open up media center on your xbox, go to Online Media, more programs, click your emulater, DONE!
Apr 05, 2009 | Microsoft Premium System for Xbox 360
Controller is jammed
Well if this is a wireless controller then try syncing it or using another wireless controller adapter.
Feb 11, 2008 | Intec XBOX CONTROLLER- PRO MINI CONTROLLER...
Powerpad Pro
since the manufactures website is down
this might help you
http://gear.ign.com/articles/355/355245p1.html
Nov 27, 2007 | Video Game Consoles & Games
Xbox remote control
Hi, i had one a while ago but i never had any problems with it, all you needed to do was plug in the little device that went into the xbox slot then the remote worked without any problems.. Sorry cant help anymore John
Jan 02, 2007 | Select Brands XBOX REMOTE DVD CONTROLLER...
InterAct Accessories InterAct PowerPad Pro (SV-234) Game Pad Logo
89 people viewed this question
Top InterAct Accessories Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you an InterAct Accessories Video Game Console and Game Expert? Answer questions, earn points and help others
