Question about RCA D52W19 52" Rear Projection Television
Will not start properly RCA D52W17
After sitting for a few hours. I turn it on and get the on light three times. Problem is getting worse. Can take up to 15 minutes of pushing the on button for it to start. After that it is fine. Second problem is I lost channel three with just a coxial cable. Had a TV repair shop tell me to use component cables, works fine. Nice TV and just moved to rural Idaho with no shops near by. Thanks, Gary
  • Anonymous Nov 24, 2008
    I have this same problem, only now tv won't turn on at all. Called the rca # to see if there was a recall out for this problem. Said it was up to me to repair thru a service tech. Won't ever buy another RCA again !
  • RCA Master
  • 8,617 Answers
Replace CP150 , CP120 and CP114 that should take care of the Issue of hard to power up. You can get the replacement capacitors at the following link with free instructions.
http://servicemanuals.vstore.ca/
Posted on Nov 28, 2008
I have a Bulova chime mantle clock, three wind, that needs sync. it is off by 15 minutes (it chimes 1/2 hour on 15 minute time etc. can you help me?
Simplest way is to remove the minute hand on dial and reseat it at the correct setting I.e one quarter turn .recheck the hour chime is on hour etc.replace glass front.
Jun 20, 2015 | Bulova Collins Majestic Triple Chime...
My cuisinart conical burr coffee grinder has started to turn it's self on every few hours
Electronic failure. If you like the grinder, plug it into a plug-in timer that only allows it to run when YOU want it to run. I have a timer like that on my coffeemaker so we don't forget to turn it off & let it run empty all day long. There are cheap timers available that will turn on for three hours if you push a little button, then shut off until next time you push the button. VERY handy, and they give you a selection of one hour, three hours, or six hours. For your purpose, one hour sounds fine. Or a wind-up type timer that stays on for only fifteen minutes, just long enough to grind coffee. Or unplug it when you're done. Or put it on a power strip with a switch.
Aug 01, 2014 | Cuisinart Conical Burr Coffee Grinder
Fuel rail pressure sensor
Don't assume the codes...check them every time. What year Taurus?
Has fuel filter been replaced? Have you cleaned the MAF sensor? don-ohio (:^)
May 05, 2017 | Ford Taurus Cars & Trucks
The bike wont start after sitting for a few days. It starts to try to turn over but then it just starts clicking.
Battery not holding its charge if you rely on your bike for transport then just buy new battery as this will never get better just worse and more unreliable it will even not start after you have ridden only few minutes ago eventually
If you want cheap fix then hook up to battery charger few hours before you need to use it but this option would annoy me after first few times personally just get new battery ASAP
May 22, 2011 | Aprilia Scarabeo 250 Motorcycles
I put a new lamp in last week. on the screen it ask me push enter so i did and the sentence went off the screen and the tv has worked good. now it is asking the same thing and i push enter and the...
reset the TV set, infront of your TV where the LED lights are there is a small reset botton that you can push with the tip of a pencil ot pen hold this botton down for 10-15 seconds then unplug the TV set and let it sit for about a 1 or 2 hours
then turn it back on it should work and if the TV still turns of after a few minutes you might have
a ballast issue sence you already replaced the lamp
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Hi, I own a 2001 Olds Alero. Sometimes the engine
to reset the pas-loc turn the to on position 10 to 15 min.then turn the key off for a few seconds,then start the car/if your security light is on do this like i said for 10 to 15 minutes.the light should go off,then turn the key off and wait a moment then start it,you dont have to wait the 1/2 hour out
Dec 12, 2009 | 2001 Oldsmobile Alero
LOST THE SETTING INSTRUCTIONS OF MY TIMEX MODEL NO. 12/874 (TX12874X)
I couldn't find a manual for your Timex, but here are the setting instructions:
Clear the timer by pushing hour and minute at same time. To set current time, hold time button down and push hour. Then hold time button down and push minute.
To set the time for light to turn on, hold the ON button down and push hour until it gets to the hour you want it on (same for Minute). To set time for light to go off, hold the OFF button down while you set the hour and minute.
Nov 30, 2009 | Timex Hardware & Accessories
There is a cap behind a heatsink on the Deflection board I believe it is CP150 or 180 which is a 2200uf/35v
Feb 09, 2009 | RCA Televison & Video
A few days ago the minute hand came off my HM Regulator keywind clock. I put the hand back on and the clock is keeping time, but the chime is not in sync with the time; re: it strikes the hour on the half...
yes
the positon of minute hand not sync with chime strikes.
you fix the minute hand as 15.minute slower and adjust the current time using time adjuster switch not with minute hand ok.
try it and solve it
Jun 19, 2008 | SkyScan 86709 Atomic Wall Clock
RCA D52W19 52" Rear Projection Television Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
