Monitor keeps coming up with input not supported and going to a blank screen
  • Computers & ... Master
  • 787 Answers
Your monitor does not like the resolution that you have it set at. I have a monitor that does exactly the same thing unless it is set to 1440X900. Check the documentation that came with the monitor, it should tell you what resolution to use. If you cannot find the documentation, reply with the make and model of your monitor and we can find it for you.
To change the resolution of your monitor (in Windows), right click on an empty area of your desktop, select Personalize or Properties, then select Display Settings or Settings (depending XP or Vista).
Posted on Nov 24, 2008
Monitor from my hard drive when I turn it on....I get the windows emblem on the screen with the dots circling around for about 5 seconds than screen goes blank and comes up input not supported.
The "input not supported" error is from the screen saying that the input signal is outside it's range. Either use a different screen or start the system in safe mode and reduce your systems screen resolution.
Jun 02, 2018 | The Computers & Internet
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
Screen keeps going blank
Hi Wendy,
Sounds like a faulty or loose component inside the screen.
It can be caused by many loose or faulty electronic parts. Best you take it to a repair shop to have it checked out.
Best wishes,
Graemevm
Apr 06, 2010 | Computers & Internet
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Input not supported
could you please tell spcifics??
example what os are you running and what happen first before it showed input not supported, try to include your graphic configuration specially your graphics card model
Nov 10, 2009 | Office Equipment & Supplies
The monitor keeps going blank after a minute or so
hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Sep 09, 2009 | Proview PL713B 17" Flat Panel LCD Monitor
Screen goes blank and message comes up saying "input signal out of range"
When does the screen go blank? Also what do you have plugged into it this most likely just because your input signal may be set at to high a resolution or frequency. Once I have more information I can assist you further.
Thanks,
Lee
Aug 11, 2009 | LG Flatron L1515S 15" LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
