1999 Dodge Stratus Logo
tom mcdonald Posted on May 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
99 stratus 2.5 v-6/no spark.will crank over.
No spark.will crank over.
torque63
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 31, 2012
torque63
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1081
Points
7
CRANKSHAFT POSITION SENSOR - 2.5L
REMOVAL
  1. Remove speed control servo from driver's side strut tower.
  2. Remove crankshaft position sensor retaining bolt Crankshaft Position Sensor
  3. Pull crankshaft position sensor straight up out of the transaxle housing.
  4. (Disconnect crankshaft position sensor electrical connector from the wiring harness connector.
INSTALLATION - ADJUSTABLE All vehicles will be equipped with an adjustable crankshaft position sensor. This can be identified by an elongated mounting hole in the sensor.
NOTE: If the removed sensor is to be reinstalled, clean off the old spacer on the sensor face. A NEW SPACER must be attached to the sensor face before installation. If the sensor is being replaced, confirm that the paper spacer is attached to the face of the new sensor Crankshaft Position Sensor and Spacer
  1. Install sensor in transaxle and push sensor down until contact is made with the drive plate. While holding the sensor in this position, install and tighten the retaining bolt to 12 N·m (105 in. lbs.) torque.
  2. Connect crankshaft position sensor electrical connector to the wiring harness connector.
  3. Attach connector to heater tube bracket.
  4. Install speed control servo. Tighten nuts to 9 N·m (80 in. lbs.) torque.
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on May 20, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2134046
Points
13357
Crank shaft position sensor
  • Anonymous Nov 03, 2012
    mike, whats the best way to get to that sensor, it's looking like the air plenum needs to come off if doing it from the top
I have a 2004 Dodge Stratus sxt coupe with a Mitsubishi engine. My code reader said misfire in Cylinder 2.
P0302, see I now it, but is it only 1? DTC error?
2 engines , or where? and up to 5 world wide, NO VIN
Engines, Mitsu. no clue told.
V6 2.7L? (so says dodge.com USA> go this?
2.4 L EDZ I4 4G64 I4 DOHC and SOHC
2.4 L EDV/EDT turbo I4 (Mexico)
2.7 L EER V6 ) i GUESS THIS IF Usa CAR. has 6 COPS
Coup?:
2.4 L 4G64 I4
3.0 L 6G72 V6
my best guess USA is VIN K engine, no vin told so engine is UNKNOWN,
it means, this, only.
Low combustion on #2 cylinder, (spark,fuel injection or compression bad)#2
#1 is on crank pulley end. #4 is at transmission I4, F1234R
rear means tranny end. oK?
v6
all V engines 99% #1 is the bank V that is most forward cyl. of all.
to the crank pulley's
2nd is always 2nd in firing order, always,and PCM dictates it.
2.7l v6 24v ffv . dohc mpi engine.
firing order, 2.7L 1-2-3-4-5-6 even odd ;odd banks.
causes (v6 cops)
1: spark plug bad #2
2: spark coil bad, COP 2 dead? or weak or boot bad.
3: oil flooded inside the spark plug well, shorting all above out.
4: injector bad #2 (omg PCM, nah) swap 2 top find it;
5: compression fails #2
only 1 code told so answer is 100% based on 1 code only 302
6: rare bad cam lobe.
7: rare cracks in head , antifreeze leaks to #2 combustion chamber.
8: oil leaks to #2 via all classic ways.
3.0L v6
2.7L
2.7L V6 order
1-2-3-4-5-6
2answers
My dodge stratus 2005 turns over great but will not crank any help
Pull a plug wire or coil and check for spark. No spark look to the crank sensor. Check fuel pressure.
2001 dodge stratus 2.4 dohc will the coil pack spark if the valves are bent on the number 2 and 3 cylinders
If the engine cranks, and the cam and crank are close to being in time, the coils should fire.
You just would not have compression on some cylinders.
3helpful
3answers
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
3helpful
Car stopped will not start is cranking over is there a coil pack on 2000 dodge stratus
yes there is a coil pack, check for spark be inserting a screwdriver in on ov the spark plu wire's and ground it out to the block and have somwhone crank the motor over, if u have spark, it might be the fuel pump or related part's
I replaced the fuel pump and filter in a 99 dodge stratus and it still wont start what can I try to fix it?
When you turn the key to "on" (not to crank), listen to determine if you can hear the fuel pump. If you can't hear, you might have someone outside the car and near the gas tank, listen closely as you do this. It's possible the pump isn't working... though you replaced it.
If you're getting fuel, try to determine if you're getting spark at the plugs.
Hope this helps... a little.
99 dodge stratus dies while driving
Were the plugs covered in oil? With the plugs that go through the valve cover you might need new seals. Did you replace the plug wires? You need to scan it for codes. It's most likely a missfire, but it could be a bad speed sensor (also called, VSS vehicle speed sensor, cam position sensor,or crank position sensor).
2helpful
3answers
I have changed the timing belt on a 99 Dodge Stratus with a 2.4 liter engine. All timing marks are aligned properly according to Haynes diagram and the engine will still not start. It tries to start
check your distributor position,double
check all marks again,make sure when u line up
the crank marks at #1 cyl. at compression and cam shaft marks!!
G
Engine willnot crank
You will need to check for a crank signal at the starter solenoid.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
